roguegeek
- Dec 28, 2012
When properly powered, the K702 will do female vocals very nicely. Yes, you absolutely need an amp to power the K702 properly. The Schiit Magni works great. I power mine with the FiiO E09K. Another one that's always talked about with those two is the O2 as well. I've tried the FiiO E07K on it and that works just fine too.
Have no experience with the T50RP, so I can't give you any feedback there.
Thanks for the reply. One thing I forgot to mention is that I listen to a decent amount of music with female vocals (from jpop and the like) so would they handle that well? Also, what would be a decent amp for them; would something like the Schitt Magni work? I've heard they're rather hard to drive, and I'm not too familiar with amps other than the <$100 portable market.
Additionally, I was thinking about possibly getting a pair of T50RPs then applying BmWr75's Simple Mods to them since it'd leave me with a fair amount of money to spend on an amp. Is that a decent idea or would I be better off just spending the extra money on something like the K702s and an amp anyway? Or even Mad Dogs?
