roguegeek
- Dec 28, 2012
They just aren't comparable. One is a closed-back can, has a colored low frequency, is highly efficient, is built to be paired on a portable setup, sounds decent unamped, and is not meant to be taken very seriously. The other is an open-back can, is way more close to neutral than anything listed since your original post, absolutely needs decent amping to sound good, and produces a signature an audiophile would greatly favor. I use them both extensively and I use them for much different reasons.
You need to provide more detail as to what you are looking for.
Originally Posted by MenacingTuba /img/forum/go_quote.gif
I have both the MDR-1R and K702 (close cousin of the Q701) and you are comparing apples to oranges there. They are very different in almost every aspect with the K702/Q701 being better overall, IMO, by a large margin. But again, these two have completely different applications, so you need to identify what you're trying to accomplish first.
Both seem like pretty neutral headphones from my research, haven't read anything detailed from some one who owns both yet...
- What's your budget?
- Where/how do you plan on using these can?
- What kind of music do you listen to and what's the format/bit rate?
- What source device will it be coming from and what amp, if any, will you be using?
- Do you know what kind of signature you're trying to find?
