Earbuds Round-Up
Oct 21, 2016 at 8:25 AM Post #12,511 of 75,492
  I am super curious to know your impression or review.
If it's really good at par with Blox TM7, i will buy in no time :)
Some tiny piece of info (mainly from the Cypherus audio X Facebook page):
"CampFred 32 ohm. QFred 70 ohm"
QFred: "Tuned for Vocal lover without sacrifying hi and low....."
The cable also looks very much like the one on Shozy Cygnus...
Oct 21, 2016 at 9:16 AM Post #12,514 of 75,492
I simply asked for very warm, with huge Bass and Smooth earbuds and while I decided to buy Monk+ with suggestions of others, AliExpress site is so confusing and they sell earbuds and cable also separately so I wasn't sure if I selecting "35mm 1click mic" option am I going to get  earbud with Mic or only Cable with Mic which you can replace but have to buy earbud separately. For that purpose only I asked if I some one has bought Monk+ with Mic and what they get. People need not to "Yawn" or Report my comments to Moderator if no one replied and as the pages update in every few minutes, I have to post it couple of times. I already posted my query to seller but AliExpress is not Amazon that you will get reply to your concern or query. I won't be wondering if they don't send the earbuds at all even after receiving the money.
Anyway. Thnx for your msg. As I mentioned earlier, I want an Earbud which is very warm, very bassy and have some clarity as well but not harsh and have smooth sound. The mentioned two earbuds I am going to order. If I get actual earbud with Mic, then it is good, if not then $10 gone in water.
Oct 21, 2016 at 9:24 AM Post #12,515 of 75,492
Just take a chance! I buy earbuds for at least $50 every month. If I don't like more expensive earbuds I sell them. If I don't like cheaper earbuds I either give them away or include them in sales of more expensive earbuds.
People in this thread buy new earbuds all the time.
Just live a little and take chances! So what if you lose $10 or even $20?
Oct 21, 2016 at 9:34 AM Post #12,517 of 75,492
Yes, Aliexpress are bad, that's why nobody on here ever uses them...
Oct 21, 2016 at 9:46 AM Post #12,518 of 75,492
Bro you do not really able understand;they does not sell cable only.
The earbud comes with mic included.As you are using your ipod so need of mic.if you have plan to use in smartphone then go for it.
You will not got any reply ;as Venture electonics have good image on market;so they will not answer noob questions.
i purchased many thing from aliexpress;do not treat them as theif.Ali is better than ebay ;as per my view.But shipping is late as its a overseas shipping.
       Hope your doubt clarified.:wink:
Oct 21, 2016 at 9:52 AM Post #12,520 of 75,492
You should take a look at Awei Es10 mic version and easy to buy. Read about it, decide if it would suit you and let us breath a little, brother.
Yes i will suggest Awei ES10 too, man this earbud has superb bass and Sub bass too
Oct 21, 2016 at 10:00 AM Post #12,521 of 75,492
Thanks for suggestion. As of now, I ordered
1) Vrme Earphone Sport Earphones Earbuds Stereo Headphones Music Headset With HD Mic
2) Monk+ with Android Mic.
Though I am planning to use it with iPod Nano but as of now I have Nano 7th Gen which is not good at all and I am not sure when I will be able to buy Nano 1st Gen as it is expensive. So until I buy that, I might continue to use Galaxy S6 Edge for Music so for some convenience of picking up the calls while listening to the music, I ordered both earbuds with Mic. Not sure how good is Vrme Earbuds.
Oct 21, 2016 at 10:13 AM Post #12,523 of 75,492
I will consider ES10 if I don't like Monk+ and Vrem. But are they more Warm and Bassier than Monk+. Some people says Monk+ has huge and deep bass and very very warm that your ear will burn . Is it so? If that is the case then it might work for my iPod nano 7 Gen as well as Bass and Warmness are what is missing in that. Altrernate, I can try to change the Sound Chip of Nano 7th Gen to Wolfson Chip.
Oct 21, 2016 at 10:18 AM Post #12,524 of 75,492
Do you have any other high end earbuds to compare the CampFreds to? I was thinking of perhaps buying a pair of those if I like QFred. The QFreds should arrive at the beginning of next week...
I'm expecting toneking ty2 and ty hi-z 650 in the next couple of weeks, not sure if these are considered hi-end. I have ty hi-z 400s, 32 ohm and of course monk plus right now. Mx985 by january when my father in law brings them over.
Campfreds have better detail, separation and the overall tonality is something i like. Only recently have i been focused on ear buds, so not much comparison save for the monks and hi-z.
I heard some folks mention qfreds being more mid centric. Though i'm skeptical til i get to demo it. If not, might take the risk and do a blind purchase since i've done worse anyway.
Oct 21, 2016 at 10:41 AM Post #12,525 of 75,492
Im interested in ty hi-z 400s, what do you think about it? Can you give me some clue about it ? My colleagues dont have the demo here in Indonesia, and im not clear with sifu ClieOs spectrum graphics review
Can i listen to it with my Topping Nx3 without being underpowered ?
