I agree with the previous posters, especially
@baskingshark. FF1 is pretty mediocre, and not a great beginner's bud. I highly recommend this one:
https://www.aliexpress.us/item/3256...dYx92p&gatewayAdapt=glo2usa#nav-specification
If this link doesn't work, go to Anaudiophile store on Aliexpress, and go to Products>Earphones. (Sorry, I couldn't figure out how to copy a picture.)
This is a very rich and warm, but quite detailed wood bud for only $15 for the Deluxe version, which I got. It is almost a baby Yinman 600 in its richness and warmth, but does sacrifice some jaggedness or peakiness in the upper treble, and the overall sound is not as full as the Yinman. But for $15, it's the best beginner bud I have found. From the site:
HiFi Audiophile Earphones Flat Head In-Ear DIY HiFi Earphone Beryllium Diaphragm Wired Bass DJ Earbuds
The best 32 Ohms driver with Beryllium Diaphragm, Amazing wide frequency response
The best earphones in the same price range!
High Lights
- EP3 earphons is based on high quality 15.4mm dynamic driver equipped with beryllium diaphragm, The diaphragm is compound of graphene with beryllium coated, It combine the advantage of graphene diphragm and beryllium diphragm.As we know beryllium is only useds for Hi-End speaker and compression horn driver, Include TAD 2001/4001/4002 etc, The price of speaker with beryllium diaphragm is very expensive.
- The dynamic speaker unit present an amazing wide scene which is the best you can find in 32 Ohms drivers, Excellent bass/ treble extention which is noticeable easily, The bass is very full and solid.The treble is very smooth and go higher than other drivers.Very smooth in the whole wide boardbrand, No any harsh.
- The sound is very neutral, Good extremely low frequency response so it can make a good atmosphere, It is impossible to find in other earphones in same price
- We offer two versions with different case and cable for your considerations, The driver is the same, The deluxe version has wider stage scene,Also a little more smooth at mid-high range
- Default version: Braided OFC cable made with 20 strands tiny wires
- Deluxe version: Integrate microphone and answer button, Sliver plated OFC cable with 24 strands wire,Very durable. Solid wood shell for driver made with red sandal wood,Very strong,Deliver neutral sound and big stage scene.
- Pease warm up the earphons for 50 hours or more so it can sing at best condition.
Specifications:
- Model: EP3
- Driver: Compound of graphene and beryllium coated
- Connector : 3.5mm TRS for default version and TRRS for deluxe version
- Gold plated connector with great anti-oxidized performance.
- Connection Type: Wire, High quality OFC cable for default version
- Sliver plated OFC thick cable for deluxe version,Very durable
- Cable Length: Approx. 120cm for cable
- Impedance: 32 Ohms
- Sensitivity: 100dB±2dB
- Frequency response: 20Hz to 20Kh
