May 4, 2023 at 7:51 AM Post #69,631 of 80,305
Got the @RikudouGoku Grand Rider 2 today.
First of all, it knocked the air out of me with the bass! Coming from Rider 1, I sure as hell was not expecting that deep and strong yet masterfully controlled bass! Simply delightful! I was grinning ear to ear.
Compared to Rider 1 these have a smoother approach, but with no loss of detail. Notes have slightly better depth, stage is bigger with more width and depth. The fit is out-of-the-world comfortable and secure! Just unparallelly great! Completely enamoured with them. The perfect alternate pair to my Serratus!
May 4, 2023 at 7:55 AM Post #69,632 of 80,305
I been really enjoying the GAS2, wish it had more sub-bass extension though. Have you tried the GAS2 as well?
May 4, 2023 at 7:55 AM Post #69,633 of 80,305
having to part with the TGXEar Red Serratus as well, check the signature!
Had I not have the SS Bell Serratus already, I would have jumped at this deal! Love the colour!
May 4, 2023 at 7:57 AM Post #69,634 of 80,305
No I haven't, but I am more than satisfied with GR2 bass, need no more. And since riku said GAS2 has a stronger low end than GR2, I doubt I would go for it.
May 4, 2023 at 7:57 AM Post #69,635 of 80,305
it looks so good, TGX threw in the adapter for free as well which I really appreciate. hoping to try another of his sets.
May 4, 2023 at 8:09 AM Post #69,636 of 80,305
I already ordered the Ripples from him. Will keep the Serratus and the Ripples as two of my TOTL pair, one for details and one for the musicality.
May 4, 2023 at 8:36 AM Post #69,637 of 80,305
Please be gentle on our wallet and stop teasing us :)
May 4, 2023 at 8:44 AM Post #69,638 of 80,305
Thank you for that! I will stick to the Yinman 2.0 600s then. I am also having a special bud made from someone that has been mentioned earlier in this thread. Won't name any names but ;)
May 4, 2023 at 1:54 PM Post #69,639 of 80,305
So I wired up my bluebells and unfortunately they're a bit of a dud. Very shrill with almost no sound below 600Hz and very little below 1k. Part of that is my goofy enclosure design; covering the grills definitely helps the low end; but the drivers are also clearly not up to the job, even minor EQ adjustments below 1k makes them crack and pop. Pretty good treble extension though! A 2-driver setup with them like those old technics earbuds could be a funny gimmick. My next project will be an IEM, but I'll definitely come back to earbuds sometime.
May 4, 2023 at 2:19 PM Post #69,640 of 80,305
Are you sure about that? I don't know of any DIY drivers that can't do 200Hz efficiently in an MX500 and those are the worst I know of in that regard. I'd start fresh with the tuning and remove all damping material and try again.
May 4, 2023 at 2:26 PM Post #69,641 of 80,305
These are 13mm biodynamic drivers from aliexpress so they're already smaller than the average DIY driver so I'm not sure about their quality. You're right though there's not much intensive damping(in fact besides some tissue behind the driver there's almost none). What would you recommend to improve it?
Edit: frankly though I'm pretty sure the shells are the main culprit. They're so flat that the magnet of the driver touches the back wall, there's hardly any air volume for the drivers to actually make bass.
May 4, 2023 at 7:03 PM Post #69,642 of 80,305
I was hoping everyone got the joke in the link. It was a reference to the joke I made regarding @FranQL's Foot uh, how do I say? Fascination. :wink:
I was going to ask what the heck that was supposed to be. ROFL
Congrats on your new shiny!😁
Thats a shame because they are pretty cool looking.
I have the same issue with the Smabat M4. There just isn't any room behind the driver in the shell, but there also isn't anywhere you can drill more ports to increase the bass and rid them of the shrill nature. Have you considered either more porting or larger diameters for the existing ones?
May 4, 2023 at 8:14 PM Post #69,643 of 80,305
There might be some room to drill, although I'll have to check how thick the drill bits I have are. Ideally how wide are ports usually?
May 4, 2023 at 10:17 PM Post #69,644 of 80,305
I don't know if there is a standard size per se, but it will probably depend on the tuning you seek, nature of the drivers natural sound, acoustics of the shell, shell composition etc... I am only theorizing and not from actual experience mind you.
This is why a lot of DIYers probably go through a lot of shells...experimenting. Having said that, I am sure there are a lot of DIYer on here that could be a lot more specific than I can be (with my mere assumptions, lacking experience), and would be glad to be of assistance to you.
May 5, 2023 at 1:56 AM Post #69,645 of 80,305
Those are likely either the Apple drivers or a copy. The Apple drivers are actually good ones. I would try experimenting with those shells more as far as damping goes because I love the look of those shells and I bet they fit beautifully. Your design skills are impressive. You should be able to find some IEM tuning papers on AE and those shells may require like Y4 or 5 or even 6. You can even buy sheets of tuning paper to make custom sizes that would fit your shells perfectly. If that doesn't work, I'd make bigger shells--the MX500 size works really well as far as bud tuning goes, but even the Lite shells can be tuned close to MX500 levels and they fit like a dream as I bet yours do.
