Can you tell us why? With slight improvement in bass response and extension the Chaconne successor would be the undisputed king of earbuds. I know you guys have been hitting homeruns with your iems lately, but us earbud folk are a passionate bunch! I would unhesitantly shell out the money for a new and improved Chaconne.
To me the Chaconne are like ANY TOTL buds/IEMs/headphones in that they have at least ONE shortcoming. In this case, it is the bass. I CAN live with it as is but adding some via EQ makes them just what you described (undisputed king of earbuds) IMO.
I use Neutron player on a iBasso DX300, high gain, filter set to NOS. The EQ settings, which are a bastardized hybrid between PEQ and GEQ (which it seems you can do with Neutron), are as follows:
62Hz BW: 1 Gain: 8dB
73Hz Q:3 Gain: 6dB (Low Shelf)
125Hz BW: 1 Gain: 4
Preamp dB: -8.6 (this should keep the AGP from kicking in on all but the most heavy bass songs).
Trust me, I know what you're thinking, but this does sound really good with them!
Keep in mind that you need to have AGP (Auto Gain Protection) turned on for this to not sound crappy on SOME songs... On heavier bass songs, it will hit a clipping point, but will only reduce the output gain rather than clip, so it still sounds very good. I know, I am too lazy to do subtractive EQing for this, but there you have it. Also, if you DO use Neutron, go into settings and make sure to set the AGP to per song, and the level slider to 0, so it will reset the AGP to normal after each song.
Are there any Maria 2 owners out there using wavelet or soundsource on mac?
Yesterday evening was Dvorak concerto night. There were some recordings I wanted to give a good listen to that I've put off for months:
- Janine Jansen's Dvorak Violin Concerto (DVC). Dunno why I never really gave this rendition a chance in the past.
- Midori's DVC. main reason why I never really sought out another DVC recording. Midori's version is well recorded and her playing is phenomenal. Let me insert here that I caught one of her recitals at UC Berkeley's Zellerbach hall ages ago and left a different person. The only other experience I had like that was catching Nathan Milstein's last performance before he died (his playing was far from well executed but everyone in that hall felt like they were watching a historical performance.)
- Jacqueline Du Pre's Dvorak Cello Concerto. Not a well recorded piece to evaluate equipment but decent considering the age of the recording. The opening entrance of the solo cello is one of the most unique passages in the entire cello repertoire, I think.
I wanted to use my Maria 2's for this session and only lasted to the close of the the first movement of Midori's DVC. The Maria's are way too fatiguing and finished out the rest of the listening session with the Qian39's wavelet eq'd to 43%.
The reason for my question: I've avoided re-setting up my measurement rig because I've since upgraded my laptop(s) and the process of making all the pieces behave well is painstaking (calibrating everything, swapping various dacs for comparison, making sure the entire audio path isn't introducing anomalies, getting things correctly updated for autoeq to work, etc.). I would also need to explore moving everything from pc to mac or keeping a stable rig on one of my pc's.... more work.
I need some additional motivation to do all this since my work has me still pushing 12-17 hour days, 7 days a week.
A couple Maria 2 / wavelets users might do the trick. Or a really disappointing moondrop chaconne experience will likely do it too. (that one should be here next week sometime.)
Edit: Ms. Jansen's version is only avail on youtube.
For fans of the violin, Hilary Hahn recently played the Dvorak, this past month Dec. 9th and 11th. I'll give this a serious listen sometime this week.
@tgx78
I don't use Wavelet (at least not for the Maria II, only for my Senn HD700), but my problem with them is the pina gain area. I subtract about -4dB (or more if needs be) from 3k, and -2dB from 2k and they are still very close to being analytical, but with less pain. Though, I have to admit, I am not as sensitive to treble as long as there isn't and stridency, but am VERY sensitive to upper mids (which these seem to have in spades). I have found these to be very good buds after some modification in that area. Though, if you can ever find the time, I would not mind hearing/following your adventures with a rig on these. Also others mentioned cable swapping. Putting an OCC cable would tame it down a bit, and thicker or even double foams would also help. Or, putting rubber donuts on would help bring up the bass, which in turn would give the impression that the highs were lessened a bit.
As to the Chaconne, as you can see from my answer above, I can't say too many things bad about them. I find the weight to be a small issue (though not deal-breaking for me), as well as the non-removable cable. Sound-wise, I am happy with the EQ that I have found. I truly think these sound better than most of the buds/IEMs/headphones I have ever listened to.
Sam L,
I think you may appreciate the Chaconne, as the upper mids are not overly emphasized, nor too recessed to over-correct over-emphasis.
Reviewers in this thread find it neutral-warm, but I find it "true neutral" (no relation to D&D.) It is only warm in relation to earphones emphasizing the upper mids as you indicate. Using them (Chaconne) right now, they are always a treat no matter what I use them for.
But who knows, you may find their treble extension a bit much (doubt it, but it seems you may be overly sensitive-or I am misreading you.)
(I do love bright steel Es, so perhaps we just hear things differently, or prefer opposite things. They should always have a core to the sound, mind you, but I do not like very warm Es as they tend to rob some brilliance from the other strings, which I do not prefer. Use medium Es and sometimes even weich because I like a bright E tone, even though I prefer gut strings in general for the lower strings.)
Seems that I will never try those Rose Technics Maria 2, as the price is even higher than the Chaconne! They better be good! Their treble emphasis intrigue me, but *not* at that price.
For me the Moondrop sound musical and neutral-very true to life, natural, open, airy, but without exaggerated sizzle. They are detailed, but not sizzling-hot. Extend absurdly well. Cymbals are so good, non distorted, and natural. One of my best earphones/headphones to be sure.
They are both Fantastic (as
@WoodyLuvr would say, God tier), but if you enjoy the Chaconne, I don't really think the Maria II will add anything except maybe soundstage width. And even then, it is not a HUGE difference (they both have a very wide soundstage IMO). You DO get a detachable cable with the Maria II though, but both are not really meant for rough and tumble actions (one to too huge to stay in your ears, and the other is too heavy). However, I bought some ear hooks that clip on to them both that work fantastic, though I only use them on the Maria II. These hooks also work on the Chaconne but hold them too far out of my ears and I lose even more bass response.
For those that like both of these buds, I can easily recommend the Yincrow 2000 as they are similar, but warmer, and fuller. Not as close to analytical, but still very clear. I would say they are more rounded across the whole spectrum, which does make them a bit different. This might be considered a slight contrast to those two I suppose, but also similar. I can't really describe it better. You would just have to listen to them IMO. Oh, and it's my belief that they come with one of the best cables I have seen for a pair of buds.
P.S. To those that know me, sorry I've been away for so long. RL crap ya' know?! Anyhow, glad to see some of the same faces still here (and new ones too.. pretty exciting).
P.P.S. I would also like to add another to
@RikudouGoku's recommend list which is the Smabbat ST10S Gold (I actually find them to sound quite a bit better than the MS2 Pro, but still like them too), otherwise would agree with almost his whole list. Only reason I can't agree with the whole list is because I haven't heard them all yet...
