It's well built and has a bright tuning.Curious about this one also, especially as it has a 4.4mm option.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Thanks, that seems to have workedHave you tried blowing them from the side? sometimes this works but if not, you really should pry it open. Not an expert with that one though.
Curious too but I want the 2.5mmCurious about this one also, especially as it has a 4.4mm option.
SiggyFraud
They do sell it with 2.5mm. I bought one myself.Curious too but I want the 2.5mm
acroyear
deleted.
Just curious if silicone rings like these actually work to help keep earbuds seated in your ear? https://www.aliexpress.com/item/1005002432593453.html?spm=a2g0s.9042311.0.0.48c44c4dksgFCw
I have a Yincrow X6 and a Qian39 on the way, and I ordered these rings last night on impulse. Guess I'm trying to justify said impulse, hahahahaha.
RikudouGoku
Member of the Trade: RikuBuds
They can work, if the shell is too small for example. those makes it a bit bigger.Just curious if silicone rings like these actually work to help keep earbuds seated in your ear? https://www.aliexpress.com/item/1005002432593453.html?spm=a2g0s.9042311.0.0.48c44c4dksgFCw
AsciiJC
Member of the Trade: ValphonicsFormerly known as ValSuki
Yup! I have and they are a nice and relaxed sound with smooth highs and mids. Treble can be peaky but is easily fixed with double foams, or adventurous enough to remove the driver from the shell, remove the tuning foam from the back and add thinner amounts to increase bass. But for the most part, double foams is the easier solution.Has anyone heard the VE Monk slim?
I noticed that you are selling your Blur. How do they compare?Yup! I have and they are a nice and relaxed sound with smooth highs and mids. Treble can be peaky but is easily fixed with double foams, or adventurous enough to remove the driver from the shell, remove the tuning foam from the back and add thinner amounts to increase bass. But for the most part, double foams is the easier solution.
MelodyMood
Is there any MMCX Version of Yincrow RW-9? I would like to buy it but the current one I see on AE do not have Mic and also L Shaped Plug which I do not prefer. PLease suggest if any MMCX Version available so I can use my MMCX Cable with Mic to use the earbuds. I read that it is better than Yincrow X6 and have better Bass, Sub-Bass and Clarity too. Thanks.
Should one use earbuds without foam? I would imagine the foam can quickly build up dust, mites and whatnot. While if you just put in the plastic, it's easier to keep clean. The foam helps the subbass, but I would rather lose some if I get a peace of mind when it comes to keeping your eardrums safe from anything that would buildup on the foams.
I bought a few of these and they are extremely useful to secure a better fit. I primarily use them to increase the girth of the earbud (think of it as a filling), and I put a foam or donut foam over this.
But it is a YMMV situation, as we have different ear anatomies and ear sizes, but this silicone ring really saved me from getting rid of some earbuds which had a poor fit.
I think some earbuds are designed to be used with foams. The full foams as u say add to some warmth and lower frequencies, so not using the foams (ie using the naked bud itself) will definitely change the sound signature. Not to mention the fit is also affected, as described above.
Actually the foams are sited outside the ear canal and if u just change the foam covers every few weeks (they are rather cheap usually), it is no issue with hygeine. Or just wipe the foam cover with a damp cloth after each listening session. If anything, IEMs which insert the eartip inside the ear canal, would be more unhygenic than earbuds, who's foams are outside the ear canal.
chavez
- Jan 2, 2014
Get RY4S Plus 32 Ohm mmcx version.Is there any MMCX Version of Yincrow RW-9? I would like to buy it but the current one I see on AE do not have Mic and also L Shaped Plug which I do not prefer. PLease suggest if any MMCX Version available so I can use my MMCX Cable with Mic to use the earbuds. I read that it is better than Yincrow X6 and have better Bass, Sub-Bass and Clarity too. Thanks.
1clearhead
- Apr 5, 2013
Unfortunately, the only model that I know that Yincrow makes with detachable MMCX cables are the Yincrow RW-1000 and RW-2000 flagship model.Is there any MMCX Version of Yincrow RW-9? I would like to buy it but the current one I see on AE do not have Mic and also L Shaped Plug which I do not prefer. PLease suggest if any MMCX Version available so I can use my MMCX Cable with Mic to use the earbuds. I read that it is better than Yincrow X6 and have better Bass, Sub-Bass and Clarity too. Thanks.
Yincrow RW-1000 is on sale now!
https://www.aliexpress.com/item/1005002806939428.html
Hope this helps...
-Clear
Total: 20 (members: 2, guests: 18)
