https://clck.ru/UGt8QCould you provide a link? Every search for LBBs comes back as no results found.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
dw1narso
- Sep 4, 2008
Q5K 'sound' is not totally neutral... I think it is a bit bumped up on the lower mid and bit of rolled of high. They market it as Reference DAC/Amp, but never mentioned that it would be neutral nor that they target it to audiophiles looking for true to the source sound. Maybe they make it to be friendlier to the greater audience.Ah, didn't even consider it could be partially the Q5k's fault too. I'll have to compare against my desktop setup later today.
Yincrow X6 is obviously on the warm side. So both does not really melt well...
Having a more 'neutral' or leaner sounding source might could give X6 a better balance... (IMHO)...
PS. I once tried to decode your cryptic location but failed .... Don't tell me... I'll give a try another time...
Where can one buy donut foams for replacement? I need ones for EB2.
KutuzovGambit
Hiegi on Penon.Where can one buy donut foams for replacement? I need ones for EB2.
RikudouGoku
Member of the Trade: RikuBuds
Hahahaha genius idea.
LBBS + parts express headband = deeper fit
(putting something like blu tack should make it more secure)
https://giantpygmy.net/shop/index.php?id_product=8&controller=product
Chessnaudio
That's hilarious! Is the fit actually better for you?Hahahaha genius idea.
RikudouGoku
It is more secure but main point is, its deeper = more basssssThat's hilarious! Is the fit actually better for you?
Ronion
- May 17, 2013
I do think that is genius! I mean obviously whoever did that is a genius. I'm looking for that headband now.
RikudouGoku
Thats my idea and pic lol.I do think that is genius! I mean obviously whoever did that is a genius. I'm looking for that headband now.
The headband is from "parts express". Its usually bought to upgrade the stock headband on the Koss Porta Pro/KSC75. I have a few of them because of that.
assassin10000
Not so much 'deeper' but more forcing a seal like when you press them in with your fingers.It is more secure but main point is, its deeper = more basssss
Well, unless you have giant earholes. Then yeah...
1clearhead
- Apr 5, 2013
+1 Definitely not for everyone, since earbuds were actually made just to sit inside the ear and not so inserted like "in-ear" monitor earphones. I will highly find this uncomfortable, IMHO.Not so much 'deeper' but more forcing a seal like when you press them in with your fingers.
-Clear
also pushing earbuds deeper into the ears would usually increase midbass to mids "boom" , and reduce the airy-ness of the soundstage.. I'm not debating whether it's right or wrong, as depending on the earbuds (and person) that method might or may not work.. , it's just at that point and the resulted sound, i rather go with straight up IEMs.
my preferred earbuds placement would be making them sit on the concha, put my thumb behind the lobule, and "pinch" the earbuds back and down (to the back of the neck)
but if it works for @RikudouGoku and he likes it, great for him! i genuinely like the idea and might find a scenario where it would work for me
How do you wear your Smabat M2sPro? Cable down or over the ear?
Ronion
- May 17, 2013
Cable down here, but the more complete answer would be however they fit you best. Ear hooks help them stay in my ears when I’m active.
)Как вы носите Smabat M2sPro? Кабелем вниз или над ухом?
