Ronion
- May 17, 2013
If I had only known a day before….
Nice !Finally i got my package "diy mx760", they feel "powerful" compare to my old MX471.
@furyossa (and others that i don't remember the nicknames) Thanks for help.
I'm glad that we help in your decision and that you like this driver.Finally i got my package "diy mx760", they feel "powerful" compare to my old MX471.
Pretty much everything sounds better with a proper amp, as smartphones are pathetically weak.Time for a noob-question, will the Smabat M2s Pro perform well directly hooked up to a phone or would one need an amp for it to perform well? I see that the specs are as follows but I'm not sure what that means in regard to my question:
Impedance: 40Ω
Sensitivity: 110±3dB
OK, thank you very much for the reply. Very appreciated.Pretty much everything sounds better with a proper amp, as smartphones are pathetically weak.
But a sensitivity of 110db is pretty high, which means it is pretty efficient. 40 ohm is higher than average but it shouldnt be hard to drive for a phone. You be fine, but getting at least a dongle will help a lot.
When you say dongle, you mean a regular USB-C to 3,5 mm adapter and your point is that, most of the time, one do not need an amp for earbuds? Or am I missing the punchline in some sort of joke about my noob-questions?Keep in mind, most of the times an 8usd apple dongle is more than enough. No need to go big buckoronies if you don't feel like it
The one that comes to my mind now is the RY4S Plus. MMCX just like the BK2 and as for the sound signature, it is warmer than the BK2 but not by a whole lot. If you're looking for something that has a similar shell to the BK2, then the ME80 is what comes to mind. Unfortunately also pretty hard to come by these days, apparently. Also, the ME80 is non-detachable.For someone that loved the **** bk2. What is the best replacement for the same price? Mine broke and can't find them anymore.
Yes, a USB-C/lightning to 3.5mm adapter.When you say dongle, you mean a regular USB-C to 3,5 mm adapter and your point is that, most of the time, one do not need an amp for earbuds? Or am I missing the punchline in some sort of joke about my noob-questions?
K´s LBBS + EQ, only way to get the X6 true upgrade as far as I know.What's a X6 upgrade these days? Looking for more detail
