What's the difference between plus and normal?RY4S MMCX PLUS
Have you tried 300ohm version that doesn't come in plus?
RY4S MMCX PLUS
I'm interested in this as well. But I would be fine without the mmcx/2pin requirement. (maybe it helps with availability lol).All, what earbuds do sound close to X6 but with mmcx or 2pin connector?
TIA
If you are looking for a sound quality close to X6 to that level, it would be best to buy a cheap RY4S MMCX and replace its Driver with X6's. Only soldering skills are required.I have RY4S mmcx plus, to my ears they are not close to X6. X6 is more balance with better bass.
Thanks anyway for your response.
Is that different from just modding the X6 with a mmcx connector?If you are looking for a sound quality close to X6 to that level, it would be best to buy a cheap RY4S MMCX and replace its Driver with X6's. Only soldering skills are required.
Modding the X6 shell with a mmcx connector will be required with special tools (hand drill/drill bit/tap).Is that different from just modding the X6 with a mmcx connector?
I meant if the sound will be the same since both are using the same driver and shell (mx500)?Modding the X6 shell with a mmcx connector will be required with special tools (hand drill/drill bit/tap).
Maybe using the same color (red?) MX500 shell and X6 driver will sound the same or very close.I meant if the sound will be the same since both are using the same driver and shell (mx500)?
No, it would be much harder. You risk damaging both pairs of drivers. RY store use very strong glue.Is that different from just modding the X6 with a mmcx connector?
The HE150Pro is one of my favorite models that I often recommend, after OG HE150 (MX500 version) which was unfortunately discontinued.Hi-Fi End HE150 Pro is "V-shaped" and known for it's bass extension.
I've also got one coming in. Should arrive by the 27th or later.on a separate note, I have a KBear Stellar w/ mic inbound. I'll review it when I get it and of course measure and build compensation files for it, if needed.
Now when you mentioned balance cables, silver-gold TRN balanced cable fits RY4S Plus very nicelyI had two Yincrow X6s, so I made one of them MMCX compatible including the shells.
I switched to a balanced cable to be balanced them, and an OFC cable to clean up the treble than original's, which was interesting to me.
But the silver-plated cable is too crisp and doesn't fit the X6.
