When I press the BS1 more into my ear, the sound becomes noticeably better
but it just won't stay there if I push it there, because it's too big... sad me
Are there any dark soundsig bud which closer to shure 215 sounding under 30$? How about vido are they classified as dark buds? In my collections vido is very good at bass sounding with smoothy mid and high and emx500 close to vido with better high present, anybody have tried willsound mk1 or abnormal duotres? Which one is upgrade from vido which are close soundsig to shure 215 if possible.
Thanks in advance
My balanced mmcx has arrived, and i tested some of my IEMs and earbuds with the ES100.
the **** PT15 and Svara-L really have noticable improvement. The soundstage seems wider because separation of instruments are more clear, and bass also more focused and bigger sounding
thanks chinmie, do you ever tried duotres? I might get willsound mk1 but i still lack of my budget and need to saving money again, perhaps if duotres suit my preference i will get it with hiegi full foam, but need comparison both of them, if only i could audition both of them
no, i haven't had a chance to try duotres. I've just noticed you also live in Indonesia, you might try the stock Sharp MD, or the recabled version from Fuad (many others do recables MD, but i got mine from him). you'll get much sturdier cable, and better sounding (more clarity and less veil on the sound) MD
Thanks in advance
Edifier H180 is a must try - I find it better than the EMX500 - faster driver, better highs and instrument separation. Sub-bass quantity is lacking, but the awesome mid-bass makes them sound more like cans than earbuds - definitely not dark though.
Hi dheepak10 thanks for answer, i already tried h180 once, it has been long time ago, it's good but i think it still lack in bass section for me, maybe because im direct it with my benjie s5, but now im using x5 1st i will try again sometime
Try heigi thick foam + 3 holes in middle. Made the sound more full and the thick heigi seals better. Sounds more like a closed back headphone than any of my other buds now, but I’m not complaining too much as the sound is fuller and more consistent.
