gazzington
Happy New year all. I'm finishing it listening to my new sony zx300 dap with snow lotus 2. Btw I love these earphones especially as they are so cheap.
i am using the new graphenes. they somehow sound differently, better on ipad , than the conexant laptop soundI don't hear much difference while using the zuperdac sadly, will listen more and see what happens
Fwiw, I was listening to the new graphenes this morning and thinking "Jeez, these sound good. But the old ones sound better I know - I'd better do some comparisons". I got as far as digging out my belkin splitter so that I could a/b them. But then the day got in the way, and now it's time to go drink some champagne.
Does Anyone know how to solder a balanced 2.5mm TRRS plug as I want to use it on the Walnut F1 mini amp. Info on the wiring done on the plug side and the driver side.Please help, thanks
On the earbud side that means normal soldering (-) on the unmarked side and (+ )on the ink dot side, See picture for the plug side. Is this correct? Thanks for the info.The F1 uses the same 2.5mm TRRS pinout as the A&K DAPs -
Tip = R-
Ring1 = R+
Ring2 = L+
Sleeve = L-
On the earbud drivers, there should be an ink-dot, denoting the + solder pad.
OK Got it, thanks again.That photo is one of the several pinouts for a 3.5mm plug, and Does Not Match what I wrote above, for the 2.5mm plug.
If you want to go by the color of ink in the photo:
RED = Tip = Right-
BLUE = Ring1 = Right+
GREEN = Ring2 = Left+
BLACK = Sleeve = Left-
