sillysally
- Aug 3, 2008
Grumble grumble, sillysally doesn't have to build a whole new system because he had the right amp for the HE-6 all along and didn't even know it, while I am still mucking about considering a new balanced DAC for my speaker amp! Oh well, the HE-6 still rocks but I don't know how much time I will spend with it in its stand-alone system now that I have I have my LCD-2, it's really a great compliment to the HD800 on the WA22.
On the bright side I only needed to buy one EML 5U4G, as it cost almost as much as the Emotiva DAC I am looking at
Yes I didn't know I had the right amp, but then again you never really know until you try it. But I did have a good idea that the WA5LE would power the HE6's.
This amp doesn't weigh 75 pounds because its big but because of the large well made transformers that Jack uses with the WA5, and that is were the power of this amp comes into play. As I have said all along, its not about volume its about power for the HE6. And because of this power you do need a very good pot and that's why I had Jack put in the Alps RK50.
As far as a balanced amp and gear's yes if it has the power of the WA5LE then that's fine but not necessary to go balanced. As with any amp its what's inside, tubes and supporting gears that matter.
