Dec 14, 2016 at 9:01 PM Post #39,062 of 42,370
I also landed about 6 months ago the WA7. Just 2 months ago the Grado GS 2000e came in. These two are meant for each other. The HD 800S? Not so much. Of all the gear I bought this year the Mojo and the WA7 are the best.
Dec 14, 2016 at 9:24 PM Post #39,063 of 42,370
I'd agree that mojo is an excellent dac I've listened to it  many time I've also heard the 800s
 hp's oh yeah I'll bet it's a nice combo with the wa7..enjoy
Dec 17, 2016 at 10:36 PM Post #39,065 of 42,370
  A question for the WA5 owners - have you hooked up a high impedance phone (like the HD650) to the 4pin Neutrik headphone connector? If so, how did it sound? Was it overloaded?
Have you run a pair of low impedance phones via the same output (like the LCD3)?
My WA5 has a 4pin Neutrik headphone connector, but I've read that this was really intended for full power delivery to hard to drive headphones like the AKG1000. It is not a true balanced output and the power delivery via this connector is far greater than the 1/4 inch headphone connector.
My WA22 also has a 4 pin Neutrik output, and it is fully balanced (when used with a balanced source) - but the power delivery via the Neutrik connector is not increased.
I have a set of Cardas cables for the HD650 on the way, with a 4 pin XLR connector, and was curious if I could run them off the 4 pin XLR output on the WA5, even though they are high impedance phones.
For WA22, I have loaded it with a set of KK headphone, the XLR outputs (both 3pins and 4pins) give much better result than the 6.3  though all outputs deliver same level of power.
I am about to experiment the WA5, and it seems that all outputs are live at same level of power too.
Dec 17, 2016 at 10:41 PM Post #39,066 of 42,370
Just a reminder to all you guys an interesting find on eBay, WA5 in 300B Mono-block pairs. I sincerely hope the AMPs to be enjoyed by someone who will appreciate them! Help with a push, check ]this offer at ebay if interested.
Dec 17, 2016 at 11:41 PM Post #39,068 of 42,370
Also, too bad, no 3-pin XLR front output for headphones use.
Dec 18, 2016 at 2:47 PM Post #39,069 of 42,370
very nice too much $$ for a used wa5..
Never seen a speaker only WA5. I don't think this is too much; I paid the same for a WA5, albeit it also had speaker and headphone outputs
Dec 19, 2016 at 12:48 AM Post #39,071 of 42,370
The price seems reasonable (there is option for best offer), considering its uniqueness and condition.
Dec 20, 2016 at 11:17 PM Post #39,073 of 42,370
First apologies for the crappy pictures.  The new cable is only 6" longer but I needed just that 6" extra.  Construction and materials are identical to stock.  The tower is a Whalen 5 shelf tower.  It was the only one I found with enough clearance on the second shelf to accommodate the height of the transformers and tubes.  The load capacity for the shelves are just 50 lbs so the transformer(40 lbs) went on the bottom shelf.  The amp section(34 lbs) is on the second shelf.  The Directstream DAC and Auralic Aries Mini streamer on the third shelf splitting the amps.  Cavalli Liquid Gold is on the fourth shelf.  The hangers for the headphones (LCD-X and ETHER) did not work with the glass shelves so they sit on a towel on the top shelf for the time being.
Wish i had the space to do that. And actually not surprising you are having positive results because that would make it/them with less interference.
Dec 20, 2016 at 11:25 PM Post #39,075 of 42,370
Decided to give Joe's (Abyss) work with KR Tubes a go. Chances are high that they will be outstanding if Joe has anything to do them. The following are on their way. This is a link to them.
https://www.thecableco.com/Product/300B-Balloon-HP "designed for serious Headphone listening" Not sure about the 2A3's of the one sI have tried they tend to be a bit too clinical for my tastes.
300B Balloon HP
2A3 HP
274B HP
Did you get the kr 300b and/or the 274b? How was them?
