Badas
- Jul 9, 2014
I'm interested in what glenn said. If there might be problems with this ss cap, when would they show up? Is it the sort of thing that would actually make the amp start blowing up in a year or 2? Or a better question, what will it do to driver/power tubes? Shorten their lives? That is the big question, as there is a finite supply of the good old driver/power tubes. Not all of us have 300 years' worth of tung sols. You would think that if the power is cleaner and more predictable, it would actually lengthen the life of the other tubes.
I think it will lengthen the time of the tubes. Voltage fluctuation from the rectifier can't be good for anything electronic. SS is providing cleaner even power.
The only thing that is warned about SS rectifiers and other tubes is a soft start. Where the full power from the rectifier is not added immediately to other tubes. My WA22 has a 22 second soft start which is fine. WU4GB also has a 2 second soft start built in which also helps.
My drive and power tubes have never sounded so stable. I'm not pulling out the Weber Copper Cap anytime soon. Amp seems it's most stable and it sounds its best. So time will eventually tell.
If my amp does eventually blow I've decided I would get it re-built and modified for the tubes I want.
