a1uc
Member of the Trade: Reseller
- May 1, 2012
The one you can get the best price on
Hi guys, I was just wondering which one between HD800 and HD800S fits WA22 better? I usually listen to piano, symphonies, classical music.
Thanks a lot.
I have owned all three. WA22, 800 and 800S
800s is sooooo much better. Better low and not so harsh highs. Using them now with v281 SS amp because it quiet and fast.
Go 800S you won't look back.
May I also ask what dac are you using?
Well I definitely don't want my amp to blow up. It sounds like theoretically those Webers are safe. While I wait for someone else to try it, I did have something show up at my door today
They pretty good. I'm not sure if they're $4k good though. People said give them some time to burn in. I'll wait a bit before deciding.
That is a very sexy pic. Congrats on the new HP's. That is one heck of a rig.
I can report 3 more on and offs with the WU4GB rectifier. No issues at all. I actually think the amp is running better than ever. Everything seems very stable. No hum, noise or anything. Just super warm, lush and detailed sound.
Another side effect benifit from SS rectification seems to be no magic second hour sound effect. My amp is sounding about 98% as good as it ever gets from startup. There isn't a big leap forward in quality after the tubes warm up after an hour.
Can you hear a difference? I find it odd this reviewer can't.
https://www.youtube.com/watch?v=Yfa_gsj27Xg
Looks like he is using the Shangua (whatever it is) rectifier. That and the other tubes should only be used for burn in only. WA22 sounds average in stock tube form.
What does everyone think about these TS 6F8Gs on eBay? Do you think they are real TSs?
http://m.ebay.com/itm?itemId=262618084080
They might be labeled Tung-Sol however that is a Sylvania made tube (very average). You can tell by the ridges on the plates.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
