TonyNewman
- May 28, 2014
I have the pleasure of introducing a WA5 into my home setup and I'm suitably impressed with the tone. I'm running Abyss with it and feeding it redbooks and HD flacs via a Bricasti M1.
I'm finding it very laid back though. Almost too laid back and not fast enough. Maybe I just need to adjust my perception as I've also running a LAu which seems more forward and certainly faster. I'm gonna try some AQ Sky RCA interconnects between the Bricasti and the WA5 this weekend to see if its the custom gold interconnects that's muddying up the SQ.
Any idea what tube combos I can roll with to add a bit more clarity?
No mention of what tubes are currently in use. If that is stock tubes *ACK*COUGH* then almost anything else you stick in the sockets is going to make things better, perhaps much better.
I would suggest the Brimar rectifiers as a starting point - very inexpensive and very high quality sound for the money.
Drivers - TS RPs or NUs (not the 6F8G if going NU - these struggle to power the 300Bs and can get noisey). The NUs are more coloured than the TS RPs, so if clarity is critical the TS RPs might be best. Note that there are versions of the TS RP that are much less expensive than the 6SN7s. Mine are all 6SL7s/6C8Gs and they sound fantastic. These can be had for a lot less than the 6SN7s. RCA 6C8Gs can be had very cheaply - these are very detailed tubes, but are a little dry.
Power - The EAT is the detail/clarity king of the 300Bs I have tried. Extremely transparent tube with great extension up and down. Almost SS sounding for a 300B, if you know what I mean. Don't expect much midrange magic from them, but if you want transparency this is perhaps the 300B for you. I sometimes use it for instrumental / classical listening and it is superb for that, but for vocal-centric tracks there are better choices out there.
