isquirrel
- Dec 29, 2012
does anyone know if the Woo audio transport can play hi res cds.?? like HD tracks cds?
Best person to answer that is Fririce0003 he has one.
I need to understand better exactly what the high and low impedance jacks do on a Woo amp. Is it correct to say that the only technical difference is that each jack is tapped from a different spot in the secondary windings of the output transformers? Which means that the high jack will deliver a higher voltage but with a lower maximum current? This explains why the high jack produces the same volume at a lower setting on the volume knob than the low jack. Now assuming I have headphones I can drive to my preferred volume perfectly well on either jack, is there any technical reason why there would be a SQ difference?
Let me partially answer that... I assume output impedance (http://nwavguy.blogspot.com/2011/02/headphone-amp-impedance.html) as presented to the headphones is also changed by where you take the tap? While output impedance supposedly has big effect on freq response for dynamic drivers, it doesn't affect planar drivers, right?
How available and what am i looking at regarding cost? Roughly.After several weeks on listen I have to say the brimar 5z4 is one of the best rectifiers out there to my ears. Love it. U52 brimar is next.
Very nice.
Think I do like the black base regular 5z4g (no y) a little better tho
Thanks.
I'm currently running a pair of Mullard EZ80 in my WA2 . I'm new to tube rolling my Woo so I don't want to sound too dumb here but, how much of an improvement would I get going to that brimar (if any)? In your experience.
