TonyNewman
- May 28, 2014
Yep - form over function. Not a critical thing, just a minor annoyance.
Will there be an update to
The new version added a HI / LO LEVEL switch, and a HI / LO power switch. The HI LEVEL and HI power setting will output approx 8W. This setting is recommended to use for inefficient headphones such as Abyss AB-1266, HifiMan HE-1000, HE6, and AKG K1000. Yes, there is a lot of power going into headphones but you don't have to use all 8 watts. You can use the LOW power setting, approx 1.5W, to make all other headphones to sing properly.
In the previous version of WA5, the XLR output (HI power output) lacked the ability to adjust output strength and thus limiting the volume control range for normal listening. The new version has a cure. We added a LEVEL switch to do just that. The LO LEVEL setting cuts down the power significantly so you will get plenty of volume to play with even on HIGH power mode. You will be sure to find one setting to make your headphones to dial in.
Cheers,
Jack
Jack speaks to the previous version of the WA5 above. But the LE also got refreshed to my knowledge.
Cheers,
Jack
Here are the highlights for the new versions.
New features:
WA5-LE ($3699)
- High power 1/4” and 4-Pin XLR headphone outputs (up to 8watts)
- User selectable High or Low output LEVEL to match headphone sensitivity
- User selectable High or Low impedance to match headphone impedance
WA5 ($5899):
Same as WA5-LE plus the following features and benefits:
- Speaker outputs x 2 (8 watts per channel @8 Ohms)
- Premium internal parts included (V-Cap, Jensen, Black Gate caps)
- XLR input x 1
- WBT Nextgen 0210-Cu RCA inputs x 2
- WBT Nextgen 0710-Cu Speaker terminals x 1 set
Hope this is clear.
[COLOR=222222]New features:[/COLOR]
[COLOR=222222]WA5-LE ($3699)[/COLOR]
[COLOR=222222]
WA5 ($5899):
- XLR input x 1
Hope this is clear.
[/COLOR]
Jack,
What's the difference between the LEVEL switch and HP Output switch? How different does the new WA5 sound compared to the old WA5?
Tonight for the first time I'm using the Brimar 5Z4G with the NU-6F8G's in the WA6 > RS1i and right from the start the WA6 is dead quiet! When I use the UE-596 with the NU-6F8G's I have a very slight hum from the NU-6F8G driver/power tubes…I guess the latter have a slight interference with each other?
