effles
- Mar 11, 2015
That sucks and I feel bad for recommending the TKs. Mine have been flawless, and I still like their sound, but maybe I was just lucky.
You sort of have three choices with tubes:
1. Buy NOS tubes from a reputable dealer --> $$$$, but a good experience if you are willing to pay;
Example: https://tubedepot.com/t/tubes/preamp-tubes/6dj8-6922-ecc88-e88cc-cv2492
Or, go crazy: https://tubedepot.com/products/telefunken-diamond-bottom-cca-gold-pin
2. Take a chance on eBay --> hit or miss; so far, I feel like I've done well, but it's still not cheap and you need to do your homework;
See: http://www.audioasylum.com/scripts/d.pl?audio/faq/joes-tubes.html#6DJ8
3. Buy newly manufactured tubes from a dealer (i.e. your failed TKs) --> less money, easier to replace, and (from some) questionable SQ.
My advice: take it slow and do some reading on the tube threads (recognizing that opinions are just that and not everyone likes the same thing).
Start with something that has near universal appeal. enjoy them for a while, and avoid the search for "Holy Grail" tubes - that costs real money and is never-ending.
But, to answer your question, try these:
https://tubedepot.com/products/philips-miniwatt-sq-e88cc-6922-gold-pin-holland
*And, no, I don't work for tube depot.
Oh, it's not your fault at all! They're great sounding tubes, but I'm probably just unlucky.
Thank you so much for the suggestions, I'll definitely consider all the options, but those Philips look great. Thanks!
