leng jai
- Aug 3, 2005
I'm new to this - how would I go about using the WA2 as a preamp to my integrated amp? Is it even possible?
I ended up not getting a power conditioner today. I looked at the specs of my surge suppressor already in place, and it does filter EMI noise already. I can't justify paying more on a conditioner than I paid for the amp. Other problem solving steps will be investigated in the mean time. Maybe I'll get an isolation transformer.
The only thing I really know for sure about cables is I don't want any from ACME! I am currently using the WireWorld Silver Starlight USB. Does it make a difference? Yes. But, many others can as well. It is going to be device/system dependent. Some are going to sound better or worse, with others simply sounding different.
So, the next time you highly recommend a cable to me as the next best thing, I'll listen to you... and maybe even the cable. But it will really depend on my system. Occasionally, I'll swap in the USB cable that comes with whatever device was ordered.And I'm quickly reminded that USB cables DO matter!
FYI~
The Cable Co. has a lending library of used cables. This may give you an opportunity to try a few different cables of interest or out of curiosity.
Im going to order the WA3 but I wonder if changing tubes is a must ? Cause when I read all this comments it seems obvious to roll tubes. Isnt the stock tubes good enough or do u roll tubes mostly cause its fun? I wonder this cause my wallet wont let me buy other tubes after my WA3 purchase. I just want to let my DT990s sing, will the stock tubes do ?
Well, I tried one last ditch effort today.
I unplugged EVERYTHING in my apartment except for my amp and the source. I wanted to see if this had any effect on the noise. Now, I know my neighbors may, but if the power supply was at fault, I expected to find some cause to come from my devices.
Nothing. Same noise.
It's a low grade noise, and I can't hear it while the music is playing. I guess it's of no tragic consequence, but it annoys me to all heck.
It can be one of your neighbors has a light dimmer going it is hard to filter that noise. Maybe the amp always had this buzz and you didn't know it till now when you started
tube rolling. If you can't here it with music just ignore it before you spend allot of money to get rid of something you cant here with the music.
