In addition to what @wormsdriver noted above, before de-soldering the wires use a multi-meter to check which is which and place a mark on to indicate which is +/- or draw a picture notingOne question though: how do I tell the positive and negative on each side of the driver?
post your grado mods....
- Feb 1, 2011
Tix88
- Jan 29, 2013
Magnum V8 driver, rosewood cup, Turbulent labs headband, detachable SMC cable , cable canare , viablue splitter and 3.5mm jack, gimball grado and generic g-cush pads .
I am very satisfied, the more I try a silver cable
@Tix88, are those brass screws used to hold the cups on the gimbals?
Tix88
- Jan 29, 2013
161013997441 on ebay. It
Is that a part number? I did a search with the number but nothing showed up. You can paste a link to it like this:161013997441 on ebay. It
https://www.ebay.com/itm/Grado-Alum...218115?hash=item4b16bfd603:g:bLkAAOSwZQRYfRYS
Concur, I was unable to find it as wellIs that a part number? I did a search with the number but nothing showed up. You can paste a link to it like this:
Tix88
- Jan 29, 2013
@Tix88, cool find, will have to get some soon but will have to find a US vendor since they don't ship to US
BrianKT
- Mar 18, 2011
Interesting. Let us know what you find.@Tix88, cool find, will have to get some soon but will have to find a US vendor since they don't ship to US
Tix88
- Jan 29, 2013
https://it.aliexpress.com/item/4Pcs...108.1000016.1.48f8f1c7JHrG6a&isOrigTitle=true
I hope I was helpful
Very helpful, Thanks for the link, will have to do more searching since $16 for 4 bolts is quite expensive.
larry piencenaves
question here guys, what dac do you use for grados? or do they need any. coz im just playing it directly to my laptop and phone. and maybe im missing out on something
Mojo, Cambridge Audio dacmagic 100. But any dedicated dap should really be an upgrade over your laptops audio chipset, after all there’s plenty of reviews to look through on here.
larry piencenaves
thanks.. but I dont really want to spend huge money for dac right now, can you suggest any affordable ones that are good?
