If that's the case the bass-heavy must be huge. Does the big bass one obscure any of the rest of the sound =is it that much bigger?
Is it sort of a "luck of the draw" as far as what version a person gets, or is it consistent within particular models?
One thing I just realized is the baffle has all those holes in it ( no kidding ) but someone must have tried cutting that away so it doesn't obscure the driver. What's that sound like?( AT-2 style mod)
It's not so much tame the bass I would say as give it a better body and the cans better spaciousness. Perhaps that is taming it
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
It still rivals the hp-1 so far from initial impressions. That may change as I a/b more
I did nearly the exact same mod to the
HP-1 just now.
----Lined backs with 1/8 inch thick Creatology brand adhesive foam= A ring around the rear recess and a disc on top of the hinge assembly pressed down into the dip of the silver retaining cap.
----Disc of the Arctic Bamboo with notched bits for screw posts, then another on top of that without notches pressed down. It rides up the sides to take care of damping the perimeter vents and a tight damp to the driver also as the raised foam on the cup hinge presses the felty stuff well.
Really nice I actually want to listen to these now whereas before they just sat there and I couldn't tell you the last time I bothered even picking them up. 6 months ago maybe or more?. Even stock they sort of just sat there.
I tell ya this thin Creatology adhesive foam is also
excellent stuff, especially the price @ ~1.75 a sheet, great for tight areas and it does wonders far as I can tell.
OK UPDATE for iQem and the Philips ( his model400 also )
Philips 6326 ( no not 6325 single entry ) dual entry Electret - TRS jacked - hence the crappy transformers in the cups. Think they are 1000 ohms.
Ready for a project transplant.
80 mm drivers!
The backplate serves as the contact and pressurized retaining mechanism for the driver layers.
Interestingly the EM6721 Philips electret i just recabled to Stax cabling ( run off Stax adapter ) simply has a wide open stator rear, none of this funky backplate/retaining plate junk.
iQem I have no idea what style yours have.
Good luck getting into them without
ruining the things too.( you can't )=
before anyone freaks out I got these so dirt cheap and in not-so-great cosmetic condition to do just this. Search and destroy.
For a possible transplant . Possible maybe not so much now. We'll see.
...(Lightbulb flickers on above head )==>Maybe add thicker spacers to increase BASS POTENTIAL , recable to stax adapter, and secure the driver without the rear plate? Hmmm. Now there's an idea!
Do you think it would reflect nearly everything and do you think this backplate would contribute to why these are very treble happy. I think so myself.
What's wrong with a different method to secure and make the contact to the stator, would have been cheaper. Did the company even test these, maybe it was a sound of the time.
I dunno.
here's the goods for those "innerset" in these.
Impossible to even see the seam flex on the cups so i had to go the sidecutter route. They are (
were rather ) bonded/secured at 5 or 6 key points around the perimeter,
very well secured.
Same useless tiny transformers. I now have 2 sets ( set from the EM6721 also ) wondering about doubling them up somehow, but then again each only outputs according to it's design right ..( right???)
notice the four tabs that make contact with the stator.
gorgeous 80mms of driver real estate. Untapped potential possible?, just look at this thing.
![](https://www.head-fi.org/attachments/675641/)
