garcsa
Member of the Trade: Mandarines IEM Memory Foam Eartips
- Mar 23, 2011
Hi joker
Would you happen to know the driver used inside the klipsch x10i by any chance please?
Thanks
Hi,
I'm extremely new to IEMs and am looking to buy one for around 130 dollars max. I've been looking at the Brainwavz B2, Re--400, a-jays(the five is coming out soon, should I wait for that one do you think?), Shure 215 and audio technicas, and the velodyne vpulse.
I like to listen to rap(jayz, kanye), all the pop songs on the radio, rock(rhcp), alternative. I do like bass, but don't like it to be overpowering.
What can you suggest?
thanks
Well, looks like everyone else thinks it should be the RE-400. I agree that it's a great earphone but my one concern would be its bass quantity - it's got a little more punch than the B2 you were also looking at but not nearly as much as the SE215 and vPulse, for example. The statement "I do like bass, but don't like it to be overpowering." is pretty vague - it could mean that you want enhanced bass but just not completely overblown (which would lead me away from recommending the RE-400) or that you are okay with a balanced-sounding earphone as long as it's not bass-deficient (which would make the RE-400 a good choice).
Hope it is okay to post again. XD After careful consideration and multiple threads, reviews, etc. I have thought about the following headphones:
Vsonic GR99 - Amazon
LG Quadbeat - Amazon [ Like Joker suggested. ]
Philips SHE3590 - Amazon
Donu Trident - Ebay
Vsonic GR02 - Ebay
VSonic R02 Silver - Ebay
Astrotec AM-90 - Ebay
The Ebay ones are from Lendmeurears. The reason I upped the budget alittle is due to the free shipping on the Ebay items. Out of all these, what do you think is the best deal? Comfort is a big deal for a small - medium size ears. Sound, I believe would be like Warm/Neutral/Balanced. Something that does not shake my head with the bass. =P Though I can enjoy it.
Thanks for helping!
Is there anything similar to the re400s that come with a remote/more accessories? It can be a little bit more expensive.
thanks
Yep, Philips Fidelio S1. I agree with quartertone's assessment.
One of the Klipsch KG drivers. I was under the impression Sonion manufactured them but I can't remember where I got that idea.
Just a small query, Joker. When you tried the S2/S1, did you notice slight sibilance and maybe a little sloppiness on overall bass? I just tried a brand new pair and that was what I noticed next to my well-burnt in pair. Never noticed it as I threw them into burn-in the instant they got here and left them for 3 days before actually listening to them.
[size=small] Hi joker,[/size]
[size=small] [/size]
[size=small] I'm just curious about your habit , do you use sometimes the EQ on your DAP? . As we know from your profile, one of your player is J3, which have a tons of preset EQs (IMO pretty good ones) .[/size]
[size=small] I know the music isn't the same with EQ, but I'm also pretty sure that we'll never hear the same sound what the engineers wanted to 'tell' us.[/size]
[size=small] Portable or home systems the same .[/size]
[size=small] I'm also sure that we have to enjoy the MUSIC comes from IEMs, HPs, speakers ... [/size]
[size=small] BTW are there any thread about this?[/size]
[size=small] Thanks[/size]
Yes, Klipsch always orders from Sonion. They've never worked with Knowles.
Outwardly, it's code-named the KG926, but that doesn't mean anything to anyone. In terms of form factor and electroacoustic properties (FR, impedance, THD pattern, etc.), it's most similar to the 26A005/8, but it may not be identical. If anything the KG926 is the progenitor to the 26A005/8, as it came to market earlier.
However, the Sleek Audio SA6/CT6 are confirmed to utilize the 26A005/8, and with some tweaks, the SA6 can be tuned to measure very similarly to the X10, with matching first and second resonance points, suggesting that the two share at least a similar driver family.
Interesting that joker and ClieOs have both given the H-100 very favourable reviews, considering how much criticism it drew from some quarters.
