Multi-IEM Review - 352 IEMs compared (Pump Audio Earphones added 04/03/16 p. 1106)
post-9357860
Post #9,991 of 16,911
ljokerl
Portables Reviewerus Prolificus
Hey Joker! I need some advice! I'm getting a birthday present for a friend, and I've narrowed it down to the Astrotec Am-90, Dunu Trident or GR02. Which one would you recommend? My friend isn't really an audiophile, so she wouldn't be too picky or detailed about the sound. She generally likes night core and pop.
You probably don't want to buy an armature-based earphone, then. As for the other two, the GR02 has that "wow" factor because of its v-shaped signature, with plenty of bass but also very prominent treble that most novice listeners will take for fantastic clarity. The Trident is more on the warm and smooth side, it will probably remind them more of their (older relative's) Bose set. The Trident also wows with its construction and overall presentation - it looks and feels like a higher-end product. If you're not too worried about all that, for pop I would probably go GR02. But really, either would be a great choice.
Joker, which iem below U$ 120.00 has a sound signature more like the 1964 V3?
Interesting question... probably the JVC FXT90 in terms of overall signature and presentation.
Indeed mate!
Btw, I got the SoundMAGIC E10 about a week ago now on your recommendation and they sound really good with EDM as well. Thanks for your input!
I got them at a steal price as well from MP4Nation, £16 shipped which is around $24. Wicked deal!
Good price!
Greetings.
I had been to a Shure dealer today in my city for se 215. He told me that he had only 1 in stock . As soon as he gave me the box I noticed that the box had been messed around with. He went ahead to make the bill and immediately I requested that I needed to check those out . I found that the foam tips were deformed and hence requested for a new set of IEM.
I have a few questions in mind..
Does the pack have a seal like the ones found in cell phone box?
Does the connector swivel with ease.. I mean are they that loose?
I read in a head fi post that the connectors are copper plated and oxidise quickly and hence the sound cut.
Although I have booked these I would still love to have all these doubts cleared.
And one important point, these were manufactured in June 2012. So connector problems may have been resolved?
Unfortunately I don't take photos of packaging and I really don't remember what SE215 packaging looked like. June 2012 should be fine, though - supposedly the issues were solved soon after I wrote my review, which was back in 2011.
The connectors do swivel pretty easily so that really doesn't you anything.
Reactions: gunnertown
post-9359304
Post #9,993 of 16,911
nicholars
This is an excellent resource for finding the right IEM... I think that IEM you get a lot more sound for your money compared to headphones... In sound quality a pair of £100 IEM is better than pretty much any headphones under £300.... Except for maybe comfort and soundstage.
post-9359483
Post #9,995 of 16,911
kaixax555
post-9360481
Post #9,996 of 16,911
Endcode
Canton, Michigan
Canton, Michigan
Hey guys, I'm in the market for some IEMs $150 and below. I got recommended the EX-600's, because my priority was for piano/ orchestral music, and I would favor in the timbre and note presentation. The point of reference for me is the B2's, which are absolutely wonderful sounding, although the note presentation seems to be a little lean for me to call realistic, and I'd like something with a slightly more tame treble. Would an IEM that is (slightly) on the darker side of neutral suit my needs? The IEMs i am looking at are the HA-FXT90, TDK BA200s, RE-400s, SM2s, and the EX-600, My price strecher is the GR01, if the difference to the B2s is quite a bit. Any recommendations?
Thanks!
post-9360537
Post #9,997 of 16,911
dweaver
I would say RE -400 or SE215, or Fidelio S1
post-9360665
Post #9,998 of 16,911
ljokerl
SM3 if you can get it under 300, or else it would be SM2 I guess
Agree.
Thanks!
The RE-400 would be a good one, or the RE262 if you can still find one. From Philips both the Fidelio S1 and S2 would work. I think the S2 is a little warmer-sounding overall so it might be better for you. I would not recommend the GR01 as it's probably not different enough from the B2, or the SM2/FXT90 because they may be too different. No experience with the BA200.
post-9360918
Post #9,999 of 16,911
Katun
Washington
Washington
Am I the only one that didn't like the RE262's scooped out upper midrange? Reminded me of the W2's sig. I find the RE-400 quite superior to both.
post-9361504
Post #10,003 of 16,911
Amitl
i just won the MEElectronics Instagram contest :)
and i'm supposed to get a 100$ gift certificate...
which earphones should i chose? :)
post-9361513
Post #10,004 of 16,911
Lifted Andreas
Formerly known as geko95gek.
United Kingdom
United Kingdom
I disagree.
My £34 JVC HA-S500 are just as good if not better than the Yamaha EPH-100 which I bought for £100.
post-9361600
Post #10,005 of 16,911
Amitl
can anyone give me please a link to a impedance adapter?
i keep hearing about it, and i read it might make the MEElec A161 sound better,
but i just can't find anything on amazon/ebay
Users Who Are Viewing This Thread (Users: 1, Guests: 4)
  • Top
