JudgeDreadLocks
- Dec 22, 2010
I see. If I run the hmdi through the tv and then plug in using optical out, would it be the same as optical through the console?
You sure? I heard they don't come with the Y cable anymore, is there a place where I can buy it if it doesn't?
http://www.youtube.com/watch?v=6FxOaI8PHxw&feature=feedu
MLGSteggy's review of the PX5.
What I get from the PX5 is that if you're into heavily personalizing your equipment, this may work for you. Personally, I just want something that works, and works well without much input from me. That's the PC360 for me.
That 2.4ghz frequency is also a huge dealbreaker to many.
Seems that the MixAmp doesn't, but the 5.8 does.
http://www.astrogaming.com/manuals/MixAmp_manual.pdf
Page 10, Package Contents -- no indication of Y cable
Page 11, Optional Cables -- there's the Y cable (as "Y adapter").
http://www.astrogaming.com/manuals/MixAmp58_Manual.pdf
Package Contents lists the Y cable
JudgeDreadLocks: do you live near a Radio Shack or equivalent store? They might be able to help you out.
No, because the TV will more than likely downmix all audio signals to 2 channel, so all you're getting from the optical out is just that. This is why I'm saying to feed the optical straight from the console.
There's almost NO TVs that keep a Dolby Digital signal through their Audio out...
Tritton AX720. Same price as the wired Mixamp, less clutter as it stays near your game consoles, and all controls are in line. PLUS, free headset! It does have its hiss as a tradeoff, though I've used it and recommend it regardless.
Yess, it just has some hiss, which you won't be paying attention to when gaming. Other than that, it has the same decoding as the Mixamp.
As for wired vs 5.8 Mixamps, wired has zero hiss, but more clutter. That's the main difference. Also, wired has an RCA input (think Wii use for Dolby Pro Logic II, which does work), as well as a Digital Coaxial input (which is rarely used these days BUT, you can buy a digital coax to optical digital adapter which will give you TWO optical inputs on the Mixamp. This works always, as opposed to gambling on optical splitters/switchers which rarely ever work).
Ugg the choices. I'm going to be selling my HD600s and I need a good headphone for my laptop and maybe xbox for gaming and movies with some music. I want something that will be both really fun.I do enjoy the bass rumble from explosions and those type of things but like a well balanced audio sound too. I also want a least somewhat decent sound accuracy on pinpointing things.
Personally I'd like something I can use without a amp. But don't mind getting a cheaper little amp if needed.
I do already have a DAC and tube amp but I move my laptop around a lot and would prefer to get a small amp thats easier to move around if I need to use a amp.
Any pushes in a certain direction are helpful.
Phantasmor, I don't understand you question. Optical cables go to the Mixamp from the consoles. The headsets go to the Mixamp via the 3.5mm input.
OK, i bought the ax 720 decoder, you know, the box the headset plugs into, without the headphones, and i feel stupid now, because i realized after i bought it they use something that looks like either a s video or ps/2 jack, i want to know which one it is, and if i can buy the inline remote cable which plugs into the jack, and separates from the headset, because i already bought the thing, so i might as well make use of it
