Why not just go for the 5.8 Mixamp at that point? Trittons are awful, I've had 2 and I hated the first even when it was my very first gaming headphone, and that says a lot.
I think you're exaggerating. the AX720 headset may not hold a candle to our fave gaming headphones, but they aren't that bad for beginners looking into gaming with a headset. I liked it more than the VERY popular Astro A40s, which to me is saying a lot. Besides, the main attraction isn't the headset, it's the AMP that works just well as the Mixamp, can be bought locally (Best Buy), and you won't have to incur a ridiculous shipping charge. Best Buy has a good return policy too, so should you not like the AX720 package, it can just be returned. I believe even Walmart stocks it.
The 5.8 is quite expensive when you factor everything (it will run you near $200 when adding the rechargeable battery pack...and trust me you'll want it as this thing eats up my Eneloops, and not to mention the PS3 chat cable which is also extra) and is still more cumbersome than the AX720...just that you're not directly tethered to the console. Just because you have a more expensive taste doesn't make the Ax720 useless. It's a robust package that appeals to quite a lot of people.
The AX720 is entry level headset, no doubt. Those who wanna get into this hobby should START here, and should they wanna upgrade, all they have to do is upgrade the headset later on, and use it with the AX720 decoder box. Easy breezy.
