- Mar 20, 2010
I prefer the HE400 over the Q701. The Q701 doesnt have enough bass for me. I do prefer its mids and highs though. The Q701 with the Annie pads however, are more favorable to me though.
MLE - I ordered the new Audio Technica AD-900x. The reviews for these cans are very scarce at the moment since they aren't officially available in the States or Europe. I did manage to find a review on Amazon which said that these cans need amplification.
http://www.amazon.com/review/R203F2SJQ7D6U3
What gain setting would you recommend I use on an Asus STX to amplify these?
Thanks
I noticed that you loaned out the HE-400 to Chicolom and Evshrug (who both own the Q701). Do you know if they both still preferred their Q701 over the HE-400 for music and gaming?
Well, due to length of period away, the last guy backed out of buying the HE400 so I had to refund him. They are back up for sale. $300. Check the sig link if interested. Though sale is pending, and have 4 other people waiting, lol.
I prefer the warmer, more balanced sound on the K702 Annie over the HE400. They're both amazing, but I'm over the emphasized treble headphones, which the HE400 falls under. The Annie has a non-fatiguing and airier sound presentation, and is also much, much more comfortable for extended use. Also, its more suited for gaming.
The HE400 is mainly bass and treble centric, and nowadays I prefer bass and mid centric with smooth treble.
For you, I think you'll find the K702 Annie to be somewhat like the HD650 with more airiness, and clarity, but still on the warm, pleasant side, and not as laid back.
Personally I preferred Q701's treble, mids, and soundstage over the HE400. Not having as much bass as the HE400 is not a dealbreaker for me.
The HE400 are nice though - very clear with a good soundstage and some "V" signature if your into that. I think the HE400s is alot more reasonable and balanced than DT990.
What was wrong with my packaging?
BTW, Calpis should remember that the parts express headphones are hidden inside the box somewhere and that they go back to MLE. I know he has been dying to get his hands on them.
MLE, how would you compare the Q701 to the HE-400 and which one do you prefer?
I don't think the anniversary is all that airy. Maybe compared to the HD6x0.
It's dark and smooth compared to the HE400 though, not exactly words I'd use to describe "airy."
TYPE Open-air Dynamic DRIVER DIAMETER 53 mm FREQUENCY RESPONSE 5 – 35,000 Hz MAXIMUM INPUT POWER 1,000 mW SENSITIVITY 100 dB/mW IMPEDANCE 38 ohms WEIGHT 265 g CABLE 3.0 m (9.8') CONNECTOR 3.5 mm(1/8") mini stereo, gold-plated ACCESSORY INCLUDED Detachable 1/4" (6.3 mm) adapter
[size=medium] [size=xx-small]Signal [/size][/size]
Impedance (Ohms): 38 Effectivity (dB/mW): 100
[size=medium] [size=xx-small]>> R E S U L T S[/size][/size]
Level (mV): 1100
SPL (dB): 115.03 Power (mW): 31.84 Current (mA): 28.95
Well, there's the numbers to get you to 115 dB SPL
[size=11.0pt] Previous Audio Technicas have been very easy to drive, and the AD900X are still only 38 ohms (previous were 32 ohm I think), so I highly doubt they're require that much amplifcation.[/size]
[size=11.0pt] [/size]
[size=11.0pt] I would probably use 0 dB gain, 12 dB if your feeling brave.[/size]
Check this out.
Thank you for the responses.
I'm assuming the sound-stage will be wider/bigger on the Q701? Does this mean the Q701 will sound more 'open' or more 'spacious' than the Hifiman? How would the imaging/positioning and instrument separation compare to the HE-400?
I will be using an O2 amp with these headphones and I tend to listen to music at very loud volumes. Does the Q701 ever become harsh or sibilant in the treble?
