Chicolom,
I think you said it while sounding much less like an a-hole than me. I was worried I might make things worse, but I felt something had to be said.
SoAmusing,
My goal was/is not to flame you (which is easier on forums than Xbox), I want you to realize that the length, tone (you often seem to be talking to yourself), and statements that sound like you're claiming to be an expert, are the things that rub me the wrong way. Assumptions and questions aren't so bad, I learn all the time too and I think it's important to be open to change your mind about something which is something you do well too, but in the context of someone who plays games on a console in a dorm or their parent's house that finds this thread and asks "what's a good setup?" then a lot of those things that don't meet your goals MAY be an entirely reasonable setup for them. You know, what if someone observes this thread thinking "I want a good headset" (the main visitor), but they see posts that only $450 headphones plus $200 receivers plus $200 amps, plus a device for chat mixing, they're gonna think we're nuts and there's nothing reasonable for them, and decide to stick with some TB x12's in stereo. But there are lower-budget options for impressive audio, and upgrade paths. Such a guest may not tell from your post and explanations that these are the next steps up for you.
I will say, in your favor, that you speak with enthusiasm and mostly positively. Neither do you try to hurt other's feelings, which I may have done to you. I apologize for hurt feelings, but I would ask that you continue to mature your posting "style," I don't want to be mean but I thought
you might need examples instead of you just not knowing what some people are reacting to. I want you to know I'm not saying these things to feel like a "big man" or some sort of bully, I just want change so we can get back to the hobby and focus on that.
BurritoBoy,
I wasn't challenging you to be wrong, I will read your link and if in general I find out how to use a PC soundcard to play console audio, I'll tell you how. I was referring to the inclusion of an optical-in on sound cards at all, here's the fastest example I found first, from the cheapest Recon3D soundcard. Note the label for optical-in:
I am not saying I know how to do it and that there may not be some kind of performance hit, but if you consider that the console processors like mixamp and Recon3D USB essentially are external soundcards and work very well processing optical cable fed 5.1, there ought to be a way with a PC soundcard. It just boggles my mind that it isn't working for you and probably others, and shame on Creative and Asus if they can't make it easy as a mixamp or something. I'm not sending you money though, lol.
