- Mar 20, 2010
And I'm telling you, for me they'd slip and slide all over the place, considering I plug/unplug all manner of cables on a regular basis.
I've already been told the O2 does move. A strong enough nudge will make it slide around. The O2 weighs less than the E9, and I don't like that the E9 is lightweight and itself moves around, even with feet. The O2 is only about 66% of the E9's weight, so yeah. No thanks. In comparison, the Lyr weighs 7 lbs, and my NFB5 weighs 11 lbs. That's what I want in a set it and forget it desktop amp that won't move around when cleaning around it, plugging in cables, etc.
Not even the Asgard has enough power for the HE-4. Nothing less than something like the EF-5 or Schiit Lyr. The HE-4 will get loud out of even the E9, but it's pathetic sounding in comparison. Don't bother with the HE-4 unless you plan on getting something incredibly potent. I think in terms of cheaper amps, the NFB12 has a ton of power, though I can't be sure it's enough to make the HE-4 shine. SQ isn't just based off power alone... and the NFB5 has the same exact power specs as the NFB12, with different, high quality internals. However, the NFB5 cost me almost as much as the Lyr, after all was said and done (though it's a DAC/AMP).
That said, most headphone amps like the Asgard should work fine for practically any other headphone including the easier to drive HE400 and HE500. The HE-4 is an older model ortho which required an illogical amount of power.
From what I been told, the MStage is better than the Asgard in pretty much all regards for that price. For the price range, the NFB12 is also a candidate, with more power than either of those, though not necessarily better quality.
NOOOoooooooooo!!!!!
You guys know I love them. I just hardly use them. I hardly use my D7000 too. It'd probably be smarter to sell both, and get just get like the Pro 900 for bass heavy stuff, and like the HE400 for the other stuff. I don't find the Pro 2900 less comfy than the D7000, so I'm sure the Pro 900 would be fine. I really just am fed up with non velour pads.
But honestly, it'd take a lot to give up my D7000.
This might be a weird question...but if i buy an amp will i be able to LOWER the volume? On my PC i need to have overall volume on 20% for my ears to not blow away,but all other sounds from games are silent then too...i wish i could keep 100% pc voice but control volume on headphones.
"Topping TP-D2 Headphone AMP & USB Coaxial DAC & Sound Card Power Amplifier" |
