- Mar 20, 2010
It doesn't. Only sends it through usb devices and the PS5 controller.
Currently just SXFi dongle for games, but I'd love a line out to a better amp. I have an SDAC and a iFi micro iCAN SE setup for music, so if the GC7 had a functional SXFi analog line out I'd ditch the SDAC and the SXFi dongle and run everything through the iFi. Would simplify things.Just curious, what’s your setup like currently?
The X7 has optical out but I haven’t been able to make good use of it.
As for quality, their pads are top notch. Memory foam is just right, breathes yet has some density for comfort. Quality materials.
As MLE pointed out, changing from stock pads will alter the sound signature. Dekoni has FR charts comparing their models vs stock so you can get an idea of what will change. I use EQ to restore original signature elements using Elite Hybrids on my DT-1990.
Aren't the HD800 pads the same?Yea i know the earpads will alter the sound. I would get the OEM earpads if I could, but the Earpads for the HD700 are discontinued along with the headphones. I saw some reviews on amazon for Dekoni earpads, and they're horrible.
Very interested to hear impressions with ps5. If SXFi over line out, it would be approaching instabuy territory. Only rub is that I can’t see it besting the DAC SQ of the X7 with full sparkos op-amp upgrade.Isn't this kind of an X7 successor lite? Dolby decoding plus Super X-Fi with digital and analog out.
If the line out does super x fi it's an instant buy for me.
I don't think that's referring to SXFI. The device has a surround option OUTSIDE of SXFI. So needs to be made clear on what's getting used, as using SXFI turns off Acoustic Engine, and that's where the surround size setting is.Time to order then:
Source: https://support.creative.com/kb/ShowArticle.aspx?sid=200442&c
Would love to hear your experiences/comments, if you decide to get one.
Yeah could refer to SBX out. I'm pessimistically presuming that is what they are referring to, actually. I wonder if they worry their headphone tuning settings might not work as intended if they let users stick their own amps in the chain.I don't think that's referring to SXFI. The device has a surround option OUTSIDE of SXFI. So needs to be made clear on what's getting used, as using SXFI turns off Acoustic Engine, and that's where the surround size setting is.
Hnnngh!Time to order then:
Perhaps, but the screenshot specifically shows the text “Speakers (Line-Out)/Headphone Virtualization Off” with an arrow pointing right, implying a submenu with options.I don't think that's referring to SXFI. The device has a surround option OUTSIDE of SXFI. So needs to be made clear on what's getting used, as using SXFI turns off Acoustic Engine, and that's where the surround size setting is.
You mean like same size? I dont think soAren't the HD800 pads the same?
