anticris81
- Jul 3, 2013
Hola chicos, quería hacerle una pregunta, que me recomiendan, el blaster de sonido g6 o el blaster de sonido x7, sería conectarlo a la ps4 y la xbox, gracias.
Si tienes dinero para el X7, ese es el mejor producto para todo lo que usted puede necessitar. El G6 se necessita una computafora para cambiar cosas internal, so no lo recommendo si no vas usar una computadora. Y el G6 no tiener un amplificador fuerte como el X7.Hola chicos, quería hacerle una pregunta, que me recomiendan, el blaster de sonido g6 o el blaster de sonido x7, sería conectarlo a la ps4 y la xbox, gracias.
ok, then I'll go for the x7, thank you very much and congratulations for this magnificent thread.Si tienes dinero para el X7, ese es el mejor producto para todo lo que usted puede necessitar. El G6 se necessita una computafora para cambiar cosas internal, so no lo recommendo si no vas usar una computadora. Y el G6 no tiener un amplificador fuerte como el X7.
It's the non TR version. 2013 I believe the are referred to as?
Yeah that's possible. There are many astro mixamp models...if he has the 2013 edition that would explain why he can pick up the directional cues correctly. The TR, on the other hand, has a very bad virtual surround function...
Having recently used DH on my Mixamp 5.8, it brought back so many memories and justified why I still think it's one of the best virtual surround implementations out there. It just works. And the warmer tonal character is pleasing as well.
So among all the different virtual surround devices you've tested which is the one you liked the most (for console gaming) in terms of surround sound?
Look in the For Sale / Trade section of the forum, you might find a cheap pair there. About alternatives, it all depends on budget and sound signature preference. I had the same setup you currently have (X2 + boompro + GSX) and I was happy with it, but then I started looking for something "better". This is all 100% subjective, so take my advice with a grain of salt. I'm pleased with the Modhouse Argon MK3 and they have great low end. Their problem is that they are super power hungry and the GSX is not going to bring their full potential (I tried, and they just don't sound good there). I'm also excited about the Verum One (Kickstarter) and Vokyl Erupt (Indiegogo) and they seem easier to drive. Unfortunately you can't just buy these in Amazon and get 2 day delivery... Plus you are trusting reviewers that might have different sound signature tastes.So for the last 4 years and a bit i'm using a Fidelio x2 with a vmoda boompro and that shows on my headphones.
The headband became loose over time and the earpads are becoming loose on the inside.
As I am really happy with the headphones i wanted to just buy another pair but the few pairs i can find cost more then when I bought them back in 2014.
So are there any good alternatives? Or at least some earpads that are recommended? would love to keep using my vmoda boompro and my Sennheiser gsx 1200 but if there isnti anything good with a 3,5mm connection I would settle with a modmic 5.
Greetings Fleshless
You can find X2 on AliExpress for like $230So for the last 4 years and a bit i'm using a Fidelio x2 with a vmoda boompro and that shows on my headphones.
Greetings Fleshless
