So the Xbox Mixamp will work on PC and PS4 when put into PC mode. However, the PS4 Mixamp will not work on the Xbox One, as it needs a special chip certified by Microsoft for game chat. Game audio works fine though.Wow, what’s up with Astro Mixamps being EITHER for PS4 OR Xbox? No more cross platform solutions? Can anyone recommend an amp/dac that will handle BOTH audio and chat on both systems? Think I may retire Astro all together.
Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
- Thread starter Mad Lust Envy
- Tags
- akg-k612-pro-reference-studio-headphones akg-k712-pro akg-q701-premium-class-reference-headphones-quincy-jones-signature-line astro-a40-audio-system-white audeze audio-technica-ath-ad700 audio-technica-ath-m50-studio-monitor-headphones beyerdynamic-dt-770-pro-80-closed-studio-headphones hd800 hd800s headphones over-ear philips-shp2500-37-full-size-headphone-with-volume-control sennheiser-hd-598 shure-srh1540-headphones sony-mdr-ma900-over-the-head-style-headphones sony-mdr-xb700-50mm-xb-diaphragm-driver-extra-bass-headphones soundmagic-hp200
TeeReQs
- Nov 2, 2016
The older mixamps will handle chat on both, but xbox requires a lot of extra wires to make it work. Not the most elegant solution
AverageGamer
- Nov 14, 2013
Any idea which cables are needed for the 5.8 mixamp to work for both chat and audio on the Xbox One S?The older mixamps will handle chat on both, but xbox requires a lot of extra wires to make it work. Not the most elegant solution
TeeReQs
- Nov 2, 2016
The first page of this thread has a lot of helpful wiring diagrams for setting up various devices to consoles. I never had a Mixamp 5.8, but I did used to have a Mixamp Pro and Mixamp Pro 2013. Setup seems to be pretty similar.
Here's the diagram from the front page for the 5.8:
https://cdn.head-fi.org/a/8265289.png
AverageGamer
- Nov 14, 2013
This will only work for Xbox audio; no chat ability correct?The first page of this thread has a lot of helpful wiring diagrams for setting up various devices to consoles. I never had a Mixamp 5.8, but I did used to have a Mixamp Pro and Mixamp Pro 2013. Setup seems to be pretty similar.
TeeReQs
- Nov 2, 2016
Chat as well
AverageGamer
- Nov 14, 2013
Chat as well
So a 5.8 Mixamp will definitely handle game and chat features on the Xbox One S using the Astro Y cable? Has anyone confirmed the quality of both audio and chat?
AverageGamer
- Nov 14, 2013
It seems my Astro 5.8 kit didn’t come (or I’ve misplaced it) with a 3.5 to 2.5mm cable to run between the mixamp and the controller. I’m wondering if Astro sells them or if I can purchase a cable from Best Buy etc.
TeeReQs
- Nov 2, 2016
Just buy one on Amazon, Monoprice, etc. Will be way cheaper than going through Astro. If you don't have the Y-cable, you can find those on Amazone as well.
AverageGamer
- Nov 14, 2013
Does it have to be a special “chat-type” 2.5mm to 3.5mm cable? Any links to a cable because there seems to be a ton of them. Also, since I’ll be using my A40 headset, do I even need to use the Y split cable?Just buy one on Amazon, Monoprice, etc. Will be way cheaper than going through Astro. If you don't have the Y-cable, you can find those on Amazone as well.
headphonesonly
You still play on the xbox 360? Xbox one doesn’t need those xbox chat cables. Just a 4-pole splitter like this https://www.amazon.com/dp/B071DMCZQF/ref=cm_sw_r_cp_api_i_sDEbCb4EQZ578Does it have to be a special “chat-type” 2.5mm to 3.5mm cable? Any links to a cable because there seems to be a ton of them. Also, since I’ll be using my A40 headset, do I even need to use the Y split cable?
AverageGamer
- Nov 14, 2013
No, I play on the Xbox One not the 360 anymore. I have a “4 pole splitter” Y cable like you linked but why do I need that if I’m using the Astro A40s since the audio and chat is one inline cable? My A40s have the quick disconnect cable with the mute switch that feeds by a 2.5 or 3.5 (not sure actual size) that I normally plug into the headset port on the 5.8 mixamp when used with my PS4. From what I keep reading, in order to use the 5.8 mixamp and A40s on the Xbox One S, many cables are needed in order to achieve quality sound and chat features (which many say is spotty at times). Wish I could just get a straight answer for connectivity.
Didn’t think this would be such a challenge in order to game efficiently. Starting to think I should just purchase a quality headset and another amp/dac that is both PS4 AND Xbox One S friendly. Any suggestions? I only started this post cause I got a killer deal on a Sennheiser Game One headset but seems like a daunting task just to get them setup.
Like the illustration seen here https://cdn.head-fi.org/a/8265289.png
Why is the y cable or 4 pole splitter cable needed if my A40s have the inline audio chat cable using the quick disconnect cable that came with my A40s? Wouldn’t I be able to plug the A40s quick disconnect cable into the 5.8 mixamp without the Y cable and then use a 2.5 to 3.5mm cable from the mixamp chat port to the Xbox One S controllers chat port? Confused
illram
- Nov 24, 2016
I don't own the Mixamp but from looking at the diagram the Y-cable is for the Gameone headphone + mic cable ---> single ended 3.5 mm cable. If the Gameone lets you swap out the cable for a normal 4 pole connector you can ditch the y-splitter as you said.
The old 2.5mm to 3.5mm was for old controllers that needed the chat adapter; new ones you just can use any old 3.5mm TRRS connector. Like this one. (I don't know if just mic audio even needs TRRS, but that is the same price as the normal stereo aux cable. They're cheap...try both?)
https://www.monoprice.com/product?p_id=18632
Again; not an owner, just what I would try looking at that diagram.
WhiteHartMart
Hooked up the G6 to my PS4 Pro for another quick test last night. Tried it via USB and also both USB & Optical. I could used the Party Chat 'Adjust Game/Chat Mix' in the PS4 software when just connected by USB but it was greyed out when connected by Optical and USB. Is this right?? If so, by connecting via USB I guess I'm missing out on Dolby Digital output?? Anything else??
dalemissen
- Aug 23, 2011
I don't own mine yet, Friday is expected delivery, however when I connect my astro mixamp to ps4, the following settings are required to enable chat and game audio changeless to be separate.
In audio settings, ensure output is set to optical and 5.1 Dolby
In devices choose usb device as headset and chat audio only.
This should send chat through usb and game audio through optical to mix
Total: 53 (members: 0, guests: 53)
