- Mar 20, 2010
What you read was my post from VERY LONG AGO, when it wasn't fully functional. The X7 works wonders nowadays.
Wow, ok, so I decided to put the MMX300 velours on the Custom One Pro aka Custom Game, and man what a difference it makes. It immediately expanded the soundstage and airiness of the sound.
I mean, call me crazy, but it definitely sounds better, and I'm not just saying that because I prefer velours in comfort. it really does sound a hair brighter/airy/detailed. The congestion is gone.
The velours sucks out some warmth, but it can be offset by changing the bass port for more bass.
Switching back to the MMX300 and putting the velours back on, the MMX300 is definitely a superior headset, but man considering how muich cheaper the COP/Custom Game is, if one could find 770 velours for cheap, it'd be a very nice, cheaper alternative.
Changing the pads back to the faux leather, the COP/Game still sounds good, but definitely darker.
Stay updated on Dekoni Audio at their sponsor profile on Head-Fi.
I did,it requires bt-w2 tranitter for chat audio but if you have both then I TT's a dre deviceI read that its working not perfect. Did you try it on Ps4?
Has anyone been able to test or spend some time with the Sennheiser GSP 500 here?? Thought I'd try the Steelseries Pro + GameDAC on my PS4 Pro yesterday but was massively underwhelmed and sent it straight back. Gone back to my Fidelio X2, VModa Boom Pro and SMSL 793 DAC/Amp.
Want to keep the Fidelio just for music and in honest don't find them perhaps as comfy as most plus the GSP500 add a more convenient volume control and my preferred flip to mute. Just concerned audio-wise they may be a backwards step to the Fidelios?
Hmm, if only someone made upgrade velour pads for headphones, if only, if only...
https://dekoniaudio.com/product/dekoni-audio-elite-velour-earpad-set-beyerdynamic-dt-770-880-990/
If you’ve ever wanted velour pads for a DT770, COP, or MMX300, our pads have a few features that are an upgrade over the famous standard Beyerdynamic pads. These have a flat face-facing surface to maintain the bass transmission to your ear, slow-rebound memory foam which traps heat less than pleather pads but maintain better isolation than stock velour pads, and the velour surface itself features a tighter weave and fantastic softness.
We also make upgrade pads for AKG, Focal, Sennheiser, and many other brands... we even have velour pads for the Beats Studio.
Mad, despite your name, we don’t think you’re crazy. Pads are one of the easiest and biggest impact mods you can make on a headphone, and we’re working on publishing measurement results from putting our pads on different headphones.
well, I had the same problem with the GSP 600. Not surprised the 500 seems to have the same or similar problems since it uses the same headband mechanic. Sennheiser seemingly tried hard but turns out these are the first and only Sennheisers that gave me discomfort. :|
anyway, people, try HESUVI. Give it a shot. Buy any 7.1 card with either good analog outs (Xonar STX etc.) or any 7.1 device with optical/coax out (also Xonars like the U3). "Unified Xonar" driven PCIe cards should be a no brainer in general.
Change between SBX, DHT/DHP and other solutions with a single click. Modify LS arrangement, EQ, boost etc..
@Mad Lust Envy What are your opinions on the Sennheiser PC37X, I just picked these up bc I was a huge fan of my old PC 360 that died many years ago, but after a short run with them the soundstage doesn't seem as good? Maybe its just expectations, maybe I need more time with them, have you had any experience with them?
