kevn
- Jan 12, 2011
This one will probably be the only one that will let you use an optical out to your own dac/amp and pass through the virtual surround.
How were you looking at getting the PC/PS4/Switch feeding through a single optical?
With that I'd use the USB from the PC > X7,
Optical from the PS4/Switch from the ARC passthrough in the TV > X7 (or swap if not using a switcher/TV with ARC)
(using the USB gives the best option from the PC and frees up the Optical port for the other inputs)
Can then use the Optical Out or the Line Out of the X7 to feed whatever you put into it through to the DAC/Amp with or without the surround processing or in "direct mode" (no processing at all)
I've got mine acting both on it's own and also feeding a couple of other DAC/AMP combo's for various setups and choices - optical to one and RCA to another
I'm using an optical switcher. The X7 does look like the best option, but I couldn't stomach spending $400 for just basic surround sound processing. I ended up purchasing an Astro Mixamp 2013 on Ebay to use until the Smyth Realiser A16 is released.
