Sinery
- Oct 31, 2016
Just tested sounds the same to me?
I'd say 16 bit at 36% is about as loud as 24 bit at 30%.
Not a huge difference, but noticeable enough for me.
Increasing bit depth increases the signal to noise ratio (and notionally dynamic range); the sound of dialogue or music should not shift levels between 16 or 24 bit.
I've just got the GSX 1200 so will be periodically reporting on it's abilities here.
1. Yes thanks, I read most of the thread. I'm not sure what your problem with the 1200 is, but since you asked I chose the 1200 beause it was on offer on Amazon for a lot less than the 1000.1) Read the thread, this isn't about the actual difference between 16 vs 24 bit, but what the GSX does differently when 16/24 bit is selected.
2) Why on Earth did you get the 1200?
For those interested here are the RMAA results of the devices I tested.
no one can answer?
thanks
1. When you receive it, please read the manual word by word and follow every step that is written there.
2. It works from usb 2 and 3.
I think I've discovered a bug.
Communication audio doesn't work when the device is in HD mode.
Simply switching to 24 bit (must play a Main Audio sound to kick the device into 24 bit mode) will completely mute communication audio.
Can someone else confirm?
