- Oct 3, 2015
I was thinking the Fostex TH-X00, Fidelio X1 (or X2 if the bass is still strong), Beyerdynamic DT990 Pro, or anything else you guys may recommend. Saw MLE listed the HiFiMan 400 (but he changed to NVM). Really want a different, complementary sound to the Annie's. I'm not crazy about them for rock music. MLE, I've bought a few headphones through your guide and was really happy and got what I expected. Hoping the group can help once again. Hopefully next year once I'm working full time again, I'll buy an endgame headphone setup. Really want something fun for the games coming out this fall.
Owned both the K7XX and X00 once upon a time. K7XX are essentially identical to the Annie's. They were good compliments IMO. X00s give you a fun, more intimate sound with gobs of solid bass. K7XX/Annie's give you the wider, "airier" sound with more accurate spatial cues (better for competitive gaming). However after getting used to the X00's sound, you might find that the K7XX/Annie sound too anemic in comparison. I know I did, and I proceeded to sell my K7XX for that very reason. But no doubt in my mind that they're good compliments. X00 is easier to amp/doesn't need it much at all. If the Magni has an output impedance that's less than 3-5 Ohms you should be fine for damping, which helps keep the X00 bass from getting loose. Should be fine with the V10. X00 cable is loooong though so beware. Haven't heard the other headphones you mention.
