lenroot77
- Mar 9, 2014
I did... months ago. Destiny is dead to me now though. I stopped a week before the halloween festival thing.
You will be back sir... U always come back
Can anyone recommend a decent usb lapel mic to pair with the X7 and PS4? I just jumped on a deal for two headphones that dont have standard 3.5mm detachable cables.
I have the X7.
SBX virtualization is done through the Sb-axx1, there is no downconversion to Dolby Digital. Simply NONE as the sb-axx1 is NOT at all bound to Dolby Digital in any way.
If you plug the X7 to the PC then the driver will ensure that the residing 5.1 discrete PCM audio in the I/O will be sent over USB to the X7 where the virtualization will be applied through the SB-axx1.
In the current state you either go PC -> X7 -> Headphone + ability to play with SBX via consoles or you get the BlasterX G5 -> optical out with SBX applied headphone mode - DAC/AMP of your choice.
For 110€ the BlasterX G5 is currently the best choice for PC Gamers that want to rely on their own DAC/AMP combo or duo. If you need proper console SBX as well then you gotta make a compromise as the X7 cannot output SBX applied headphone mode to the optical out.
If you use like a 3.5 mm to RCA converter piece couldn't you hook up an X7 to an external amp and still get SBX? I understand you can't use the optical and still get it.
I'm just wondering for the sake of wondering. I have HD700's and people have been reccomending tube amps to me and at some point I'd like to listen to it though one and I'm wondering if I could use my X7 as the DAC with an external tube amp and still get surround.
I do have to say though that I'm currently loving my set up as is. The HD700's are extremely wide. Love that about them. Hate to use the cliche but it sounds like I'm listening to music and games again for the first time. Loving hearing details I've never heard before. Even in things like title screens I'm picking up little sounds my HD598 and mixamp never did.
I have been using a Zalman mic for years... It's built tough!
Also I'd post your screen name on the destiny thread... Plenty of us over there.
If you are interested in directional audio, the modi will not give that to you. It ultimately falls on what you really want. I get the sense that you want surround, so get a mixamp. Or, go a step further and get an all-in-one X7.
You may be better off just getting one of these
http://us.creative.com/p/accessories/creative-bluetooth-audio-bt-w2-usb-transceiver
And hook up a clip on mic to the X7.
Edit: never mind, you are on XBox. Someone else can chime in.
Your impressions remind me of a famous Madonna song.![]()
Thank you. This is how I figured it as well. However, AFAIU, Mad lust Envy was stating that there is a distinct difference between USB Discrete PCM -> X7 USB input -> SBX Headphone virtualization from X7 headphone output vs. Optical DD Live bitstream PC output -> X7 optical input -> SBX Headphone virtualization via X7 headphone output.
So, I was merely trying to clarify what is this difference and how does one notice it.
I guess I'll find out, when I get my X7 :-D
There is a big difference, I have the X7 and I tried both setup. The Dolby Digital route is way better for Surround Sound directional.
That makes no sense. The audio is lossless via USB but won't be via DD due to bandwidth limitations of optical.
Is there a way to record the output from both?
Thanks. You are confirming, what MLV stated.
I wonder why there is a difference in the positional sound in the first place?
Also, as per your own experience, how would you characterize the directional sound differences between the USB/PCM and the Optical/DD-bistream modes?
