PurpleAngel
I need some help in regards to what i should do. I only care for audio in competitive games specifically CSGO. For the last 3-4 years I've been using pc360 and Xonar Essence STX, now either my ears are ****ed up or i need some new gear. Because i feel like i miss out on sounds in-game that e.g. my friends with pc350 and only on-board sound card can pin point.
So first of all, what settings should i be using in the STX audio center to make this situation optimal?
Currently i have:
Audio channels: 2
Sample Rate PCM: 44.1Khz
Analog out: Headphone
And not touched anything else.
Secondly if i should spend money and get some new gear, what would be the best possible setup for competitive games where directional sounds and "where people are stuff" is the only thing that matters to me.
I've been trying to find suggestions to this on here, but there's so many and I'm going nuts trying to figure out whats the best
So far I've gathered that these have been recommended a lot for this use case:
AD700x, K612 pro, Fidelio x2, HD558, HD598
As far as AMPs go I've seen the FiiO E10K, E11K and E09K recommended.
But i have no clue which headphones needs one.
Have i missed any?
Which one is best for my use case in CSGO, and if i need what AMP should i get?
Did you disable the motherboard's on-board audio, in the BIOS, before installing the Essence STX and the Asus software?
Set the STX's Audio Channel to 6 speaker (or is it 6 channel?)
Do you set CSGO to 6-channel output
I've never played CSGO, so I'm just guessing at the settings.
Try the Unified Xonar Drivers
http://maxedtech.com/asus-xonar-unified-drivers/
The Sennheiser HD558, HD598, PC360, PC363, GAME ONE, etc, all seem to use the same 50-Ohm driver.
I do not think adding an external headphone amplifier to the STX will solve the issue, as the STX has way more then enough to drive the 50-Ohm PC360 headset
