IcyRhythms
- Feb 2, 2014
I tried the optical Modi with my Omni (same as the Z but external) and returned it after hearing no difference. The DAC in the Z/Omni is quite decent and you're going to need to go a step above the Modi if you want to hear an improvement.
I ended up getting a used Audio-GD NFB-15.32, which cost about the same as the Schiit Stack after shipping and tax. The DAC sounded noticeably better than the Modi or Omni.
If you wanted to just amp, the Magni will definitely give you a lot more power than the Z. I haven't heard it so I can't comment on how it will sound.
Personally, I think the A-GD is a steal and worth the price even new. I'd recommend that.
Regarding your headphones, the 598 is pretty good for gaming and I don't think the others will be much of an upgrade. For music, tho, I suspect the K712 will be a step up. Caveat: I haven't personally heard the 598 or the Beyers or the K712.
Yeah, it will be used for both gaming and music. It's a tough call. I guess I can take the Audio-GD into consideration as well. Thanks for the helpful response.
