RXShadow
- Jul 11, 2014
Hi Mad Lust Envy,
I am really new to the gaming headphone life. Being new and not knowing any better I originally went to Turtle Beach. But I just couldn't find a headphone that really struck my fancy. There was no way I was going to pay 300 dollars for a gaming headset that might break in 6 months. So I did a lot of research and a lot of reading. I eventually came across a site that swore by Sennheiser's. So I ventured into a realm of a true audiophile.
I have looked at the PC 350 SE, PC 323D. I wasn't really sold on the PC 363D. So for quite some time I was pretty much focused on the PC 350 SE. Then I read some other sites and they swore by the Sennheiser HD 558. So then I was focused on that one. Until I read your forum post about headphones. I really liked the ATH-AD700 from what you had stated. It looked as though it might be one I might be interested in, I even found one that was well priced. But like a fool I passed on it and waited. And when I made my decision it was gone.
So now I am a bit perplexed by all the headphones I have looked at and read about. These headphones will be mainly for consoles. Xbox 360 and the PS4. I do some competitive gaming on the consoles, while I play some games on the PC I don't play anything competitive. A really nice soundstage like the ATH-AD700 would be great or something at least close to that. I would prefer to spend under $300.00. For just the head phones.
Also if you can recommend an decent amp/dac for the headphones that would be great. I had been looking at the Fiio E17 and the Astro 2013 Mixamp. And like I said I am new to this world. So which ever is going to produce the best sound would be beneficial. I will also be needing a mic for any headphones that doesn't have a mic. I already have a sound card for my computer.
Thanks all for helping me for my gaming immersion.
Hey there. I would say Welcome to Headfi, but I'm probably not the best person to say that. I'm not Mad Lust Envy, but I could give my opinion (which you should probably take it with a grain of salt)
Sennheiser's PC and GAME series are very equivalent to the 558/598 and are more expensive. If you want to go for Sennheisers, I would suggest the 598 since your budget is $300.
While the AD700 is great for its amazing soundstage, I would advice to go for something a little bit more "fun". Soundstage is great, but it's not everything, and certainly wouldn't suit you for non-competitive needs. I personally prefer even some fun on competitive, cause I do expect explosions and vehicle crashes to also sound amazing, but that's just me.
There's alot of options you can go for. An AKG Q701 is probably a better option, it's soundstage is more than enough and has good enough bass for your needs. They will need to be amped though. There's a lot of other nice options for you to choose, an HD598 or maybe even a Soundmagic HP200. I would suggest reading the reviews and see what suits you better.
For the mic, just get a modmic if you want something great, or a simple clip-on mic if you want something simple. I will let the other (more experienced people) help you on the DAC/AMP.
But like I said, take my advice with a grain salt. I'm not probably the best person to take from.
Option 1: STX/ZXR + Modi Optical + Magni
If you're going for Optical Modi, go for something cheaper such as the DG/Z. The soundcard will be MAINLY for VSS only, there's no point in overspending. Like commented above, it's still a great option and there's nothing wrong with it.
Option 2: 2 setups depending on Surround: USB Modi/Magni or Xonar DX + Amp
If you don't want VSS, first idea is a great option. If you do want VSS, your other options are better imo.
Option 3: Xonar DX + Magni
If you're depending on the soundcard's DAC, I would use the STX/ZXR more than than DX. The DX (or even better, the DG) is great for giving you Dolby Headphone on a great Optical DAC/AMP. Although I'm not sure how the DX's DAC fares with the others.
Option 3.1: STX/ZXR + Magni
That looks fine. I'm not sure about STX's DAC, but I do know the ZXR's DAC is quite good enough for great general needs.
Questions which would help choose option:
1. How is STX/ZXR DAC compared to Modi DAC?
2. Let's say you use Optical Out into an External DAC (with an Optical In) to override the soundcard DAC. Does Optical Out degrade quality over the typical RCA Out? In other words is Optical or RCA better?
Not sure. It shouldn't, but I would let someone here say for certain.
Ty all!
I've commented on each opinion, based on my opinions. Probably would advice to get someone's more experience backing just to make sure I didn't say anything stupid. There's nothing wrong with getting Opti Modi and connecting to the sound card to achieve VSS, or getting an amp to connect through RCA.
