I missed Dolby Headphone so I picked up a Xonar U7.
Too bad I can't actually get it to DO any legit Dolby Headphone. Not sure if it even can.
An update on the Xonar U7 in case anyone was wondering if it's legit...
I've been playing around with it for a few hours, and...unfortunately it seems to be a fail as far as headphone-use goes. It's gimped to only taking 2 channels from a game and upmixing it (pro-logic). No discrete channels = bad positioning.
Yes, it comes with Dolby Home theater v4 which has Dolby Headphone inside via the "Surround Virtualizer: Headphone" but you can't get it to work properly with the U7. The U7 is unable to feed it 5.1 or 7.1 channel source AND have it come out the other side as 2 channel Dolby Headphone signal (how the U3 works). The only way to get the U7 to handle more than 2 channels is to set the Xonar to "Speakers" in which case it will split the source signal into separate analog channels out the back of the U7. So your 5.1 game audio will be split between the 5 different analog ports on the back, not a downmixed Dolby Headphone stereo signal. If you only want to output via stereo using the two line-out RCA ports on the back, you have to set the U7 to only 2 channels - which bottlenecks all your sources/games down to 2 channels and kills your ability to feed Dolby Home Theater v4 (and thus Dolby Headphone) properly. Pro logic.
The U7's second output mode, "Headphones", is strictly two channel in -> two channel out. You can't set it to anything other than 2 channel. It's basically just a stereo DAC, and no amount of virtualization software is going to fix the fact that your only getting two channels from all your sources when in "Headphones" mode. The Xonar U7 has it's own virtual surround when in the "Headphones" mode, called "Xear," but it's not that good. Turning it on also disables Dolby Home Theater v4 and vice a versa.
The U7's third and final output option is SPDIF/Optical. This mode does either 2 channel PCM or Dolby Digital Live. NO 8 channel input from source down to 2 channel DH output (like the U3).
The U7 only seems useful for people wanting to drive multiple analog speakers from their PC. It's not good for gamers with headphones, as the only headphone virtualization you'll be getting will all be derived from 2 channel sources.
It's a shame, because the hardware looks and feels quiet nice. It seems well built, everything's gold plated, and it has a cool digital volume knob on top that also acts as a click button to switch between outputs. The Dolby Home Theater v4 software also looks nice and clean (a bit too simplified and dumbed down though IMO). Throwing Dolby Home Theater v4 together with the U7 was a nice thought, but it just doesn't work when you can only set your audio devices to 2 channels when trying to use any heapdhone surround. I figured Asus was smart enough to have thought that through, but I guess I was wrong.
I guess I'll be returning the U7. I didn't pay 90 bucks for a glorified Pro Logic box. Chicolom don't roll like that, you dig?
I also picked up a Xonar U3 from microcenter, and that on the otherhand works
great. Very easy to set up and it's doing Dolby Headphone properly.
