Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
Nov 25, 2013 at 8:51 PM Post #18,347 of 48,568
  How about HD201? 8323>HD201? I game in a pretty loud environment and I want something a little more closed off.
What is your budget for the headphones? Of the two listed I've not heard the 201, but I may know of some in your range that are decent and closed other than the Monoprice.
Nov 25, 2013 at 8:58 PM Post #18,349 of 48,568
i'm looking at max 35ish range. I don't want to spend so much because gaming is just a casual thing I do and I just want to be able to locate my opponents by his/her footsteps.
Nov 25, 2013 at 9:10 PM Post #18,351 of 48,568
  hmm. Well I guess the HD201's are out of the picture. I'm leaning towards the KSC75's but outside noise might be a problem.
MLE reviewed the SHP2500 on the first post. Might be able to find that in your price range. Could a semi open headphone work for you? The Superlux HD681 and HD681 EVO can both be had for that price.
Nov 25, 2013 at 10:15 PM Post #18,355 of 48,568
They look nice, but dos pleather ear cushions drive me nuts. I guess you might be able to replace them, most manufacturers charge and arm and leg for them though either up front or in shipping.
Surround sound is sort of a necessity for competitive gaming and the AX720+ is the cheapest that has that.
Also you can use it not only with the PC but with almost any console.
PS4
Xbox one
PS3
Xbox 360
Another thing is that it lets you balance game/chat volume so you can get the perfect balance between the two, the other headsets you mentioned doesn't have that and I'm 100% sure your not going to like that for online gaming.....nobody does.
Nov 25, 2013 at 10:31 PM Post #18,356 of 48,568
  What sound card (pc) do u guys recommend for the dt 990 pro 250ohm
Creative Labs Sound Blaster Z sound card (SB1500), $100, sometimes goes on sale for as low as $65.
Nov 25, 2013 at 10:35 PM Post #18,357 of 48,568
PS4
Xbox one
PS3
Xbox 360
Two things, although it is nice that it works on a bunch of systems, it really isn't necessary. The Turtle Beaches I had turned into my PC headset when my other ones broke and now I have neither and probably wont go back and forth connecting to to both the consoles and PC. I just need PC mainly. The other problem is it's $30 over budget for me, which might not sound a lot, but as it is I'm not to happy paying $100 as it is.
Nov 25, 2013 at 11:36 PM Post #18,359 of 48,568
  Thanks mate,
I was checking the blaster z earlier and i heard alot of bad opinions about the drivers, I think I will buy the Essence STX in second hand for 90 euros (110 $) , i think its the best option , right?
Essence STX for $110 is a great value, better DAC and head amp then the Sound Blaster Z (& Zx).
and the STX's headphone output impedance is 10-Ohm, better then the Z or Zx's 22-Ohm impedance.
