NewMACAdress
- Jun 17, 2011
I WIN!
EDIT 2: Just wondering, does Dolby Headphone emulate 7.1 surround?
Direct from Dolby's page about their tech: "In addition, in conjunction with content preprocessed with Dolby Pro Logic IIz, Dolby Headphone can deliver a convincing 7.1-channel surround experience."
Astro mentions 5.1 and 7.1 on their page for the Mixamp 5.8. Turtle Beach also has 5.1 and 7.1 listed on their page for the Ear Force DSS. Don't know enough about DH capable receivers to answer for them but most likely they are the same.
http://www.dolby.com/professional/technology/home-theater/dolby-headphone.html
Hmm...
What just happened was... sad, to give it a name.
I never saw Alghazanth imposing his will or making rude calls. I was curious about his arguments, and about what his cans and his view for SP was. I do think MLE overreacted in his aggresive posts.
But well... sad to see another fun thread spoiled for this kind of behaviour.
Agree with this. MLE contributes a lot to this forum but has a tendency to get too defensive. It's fine to express your own preferences and views, but it's obnoxious to do it in a tone or manner that attacks those who disagree.
Quote:Direct from Dolby's page about their tech: "In addition, in conjunction with content preprocessed with Dolby Pro Logic IIz, Dolby Headphone can deliver a convincing 7.1-channel surround experience."
To put it as a 5.1 or 7.1 would downplay what DH. There are no speaker cues. It's a full 360 degree sound field, it may as well be labeled as 20.1 surround or something. I think they label it as 5.1 or 7.1 just so people can expect something akin to a speaker setup. In any case, 7.1 is false advertisement at it's core, as optical digital cables only carry DD 5.1 or DTS 5.1 (though those gaming amps don't decode DTS). For example, if you play a Blu-Ray on the PS3 that does DTS-HD (which then downconverts to regular DTS for the optical digital connection), the signal will downconvert to 2.1 stereo, so you'll be getting a basic stereo signal sent to the Mixamp, which doesn't even come close to a Pro Logic II signal, let alone a Dolby Digital signal.
From actual experience, the Mixamp sounds better with a regular DVD than a Blu-Ray, because DVDs carry a real Dolby Digital signal which the Mixamp converts to DH properly, giving you the real virtual surround, as opposed to virtualizing a basic stereo signal to virtual surround (a song playing on the Mixamp with the DH button on...sounds worse than a song playing from a real Dolby Digital signal from like a movie).
Will the D7000 work good with the essence sound card?
Will it be able to run 7.1 or whatever it is?
EDIT: Just wondering something about the D7000, if i connect my PS3 to my new Samsung screen (the new LED 950D) and then connect the D7000 to the screen, will the headphones function properly or is the PS3 to weak?
According to what MLE has said about having the D7000 sound fine out of any source, then yes the D7000 will sound fine out of your Essence ST. As for your other question, the TV will be amping your headphones and not your PS3. And as far as I'm concerned, I think the headphone outs on samsung tvs or any tv for that matter generally suck.
Yes, a DAC and AMP. Something as simple and cheap like the Fiio E7/E9 will improve the D7000. Better DACs and AMPs will improve them even more, though YMMV. If getting an amp, I recommend a solid state amp.
