Mad Lust Envy's Headphone Gaming Guide: (8/18/2022: iFi GO Blu Review Added)
Aug 30, 2013 at 1:11 AM Post #16,186 of 48,566
Well, I would sell your Anniversary first and "turn it in" for the K712 Pro.  Not much sense in keeping them both, unless you want to compare them.
Definitely selling them, first. I'm dead broke until mid September...
Edit: I just grew a big enough sack to do the bass test since I'm now thinking about selling them. No issues whatsoever...
Aug 30, 2013 at 1:19 AM Post #16,187 of 48,566
Haha.
I tested the K712s right after I got them and they were fine.  Buttery smooth.
Aug 30, 2013 at 1:59 AM Post #16,188 of 48,566
Nothing will beat the MA900 in terms of it's comfort, weight, and just pleasing tonal signature. Hence why it's my favorite alternative to a main headphone. BECAUSE it's an alternative, and not a main, I wouldn't use the Annie or K712 as a main. So I'm perfectly happy woth the MA900 in that regard.
I'm confused.  Are you saying you don't consider the MA900 as a main headphone but an alternative-to-a-main headphone?  So you have a "1 Main headphone + 1 Alternative" policy now?  Didn't you say you're using the MA900 more than the X1...so isn't the MA900 your main headphone??
....two mains......unforgivable......blasphemy.
I reported you to Jude and Currawong for having two headphones.
Aug 30, 2013 at 2:08 AM Post #16,190 of 48,566
Haha.
It's just now beginning too?
I see someone posted a new classified...
Aug 30, 2013 at 2:15 AM Post #16,192 of 48,566
It's good you're selling those too, because the K712 comes with a nice big velvety pouch and a coiled cable.
Aug 30, 2013 at 2:17 AM Post #16,193 of 48,566
I already know; hence why they are included in my classified...
The bag I have is much more durable, though... so that will be a bummer
Aug 30, 2013 at 2:27 AM Post #16,194 of 48,566
:eek: ....two mains......unforgivable......blasphemy.
  :tongue_smile:
Well, I prefer just having just one headphone, but because I'm so happy with the MA900, I'll use it as my alternative. My X1 IS my main, just that as of late, I've been using the MA900 almost exclusively. Ideally, the X1 will get the most use, and the MA900 will be when I'm fatigued by the X1's stronger clamp or leaner mids.
All in all, the X1 will be my main music/movie headphone, and the MA900 will be my TV show/anime/gaming headphone. Still, the MA900 is actually more of an all rounder due to the better mids, still good bass, and non-fatiguing treble. Again, not saying it's technically better.
Aug 30, 2013 at 2:30 AM Post #16,195 of 48,566
And just in case this info might be useful to other MD owners... my reason for having interest in the K712 PRO is because, like chico, I found the upper mids to be a bit piercing after switching back to the AE after using the MD for an extensive period of time (chico had the same effect when switching from the K712). So I am assuming that the K712 will be a better match for the MD... rather than the AE.
Edit: Once I get my hands on the K712 I will make sure add my thoughts
Aug 30, 2013 at 4:01 AM Post #16,196 of 48,566
I'm at a point in my life where a little bit of change might be good. I've been rocking my m-stage and Pro2900 for like 2 years now. Should I get an iCan and ma900 or just put all that money towards a TH600 or Maddog or Alpha dog?
Aug 30, 2013 at 4:14 AM Post #16,197 of 48,566
The MA900 wouldn't need an iCan, and should rock out quite well on the Mstage. The higher output impedance on the M-stage won't affect the MA900 due to the impedance compensator built in.
While I LOVE the MA900, you might wanna jump into something more high end than what you own. TH600 sounds like something I'd go for if I had the funds, if only because someone compared it to a modded D7000. Not sure if that's enough bass for my taste (and I want bass out of such an expensive headphone), but it does sound appealing to me for a closed can. The Alpha Dogs are probably too technical and linear for my taste.
I loved the Mad Dog 3.2, but it was still mid-fi and closed to me. I prefer the MA900 overall, though the MD 3.2 did bass incredibly well.
The MA900 has such a low price of entry, so maybe if you wanna save money and want a warm, balanced, incredibly comfy headphone, you should look into it. The Annie (and probably K712 Pro even moreso) would be even better than the MA900 in technicality, refinement, and detail, and should be driven easly by the Mstage. I really only recommend the MA900 for those that want something affordable and competent with everything.
Aug 30, 2013 at 4:29 AM Post #16,198 of 48,566
I would go for TH600 personally.  The TH600 sounds very enticing.  I've read it does a good chunk of what the TH900 does, and is a better value.
I've read the Alpha Dogs are really FAST sounding.  Not sure if that's good or bad for them yet.
The iCan is great for tweaking the sound and soundstage lovers who like playing with the soundstage, but at default settings it doesn't quite replace the M-stage.  The M-stage is still slightly airy and with a slightly larger soundstage.  I usually prefer to listen to the iCan with a bit of sub-bass boost and the 3D soundstage over the M-stage though.
That's true, although the iCans sub-bass boost certainly helps out the MA900.
I think Calpis should go for TH600 though.
Aug 30, 2013 at 4:30 AM Post #16,199 of 48,566
The low price of the MA900 really tickles my curiosity. I would like to see just how comfy they are.
Have you looked into the velour pads off an akg 242? They should be right about the same size as the beyers.
Edit: Pretty sure I can safely buy the TH600 with my next paycheck. I do have to take my car in for servicing which is preventing me from getting them now :/
Aug 30, 2013 at 4:51 AM Post #16,200 of 48,566
If I was gonna spend so much, I'd just hold out for the TH900. XD
I'm really hoping the TH600 has sub bass like the D7000. That MIGHT make me sell off a limb for one. I should've told Justin at Headamp to send me the demo, but now it's too late. :frowning2:
Cal, I was going to send the MA900 to you and a few others, so I'd at least hold off on getting them so you can at least demo them first. I've already started writing in my review, so you guys can expect the MA900 to be sent out within a week or two at the latest. It's gonna hurt sending them out. I've grown attached to it. I think the X1 has had about 2 hours head time in the past, what, 2 weeks?
As for the 242 pads, aren't they using a snap on mechanism like the K70x? That won't work with the MA900. It needs to be a slip on type of pad, and it needs to be big in diameter.
For the MA900 loaner. I'm looking at:
Change, Evs, Calpis, MattTCG, Nameless (he just bought Chico's), Chicolom (no need).
