okay so i just found an old pair of Aiwa K26P headphones (remember those? older inexpensive folding headphones with lots of bass) at the bottom of a drawer which i remembered had a loose wire on the left driver,so i thought "what better cans to practice my soldering skills (or rather lack thereof) on!" and so i opened up the cups and saw the black wire had indeed come loose from the solder on the left side driver,so i dug out this 40w radioshack soldering iron my neighbor gave me a couple years back along with some flux and solder and heated up the soldering iron,placed the wire over the contact area on the K26P driver and used the iron to heat up the solder,dabbed it onto the contact of the driver and i let it cool and harden and voila! success!
so...between that experience and this video -> https://www.youtube.com/watch?v=f6BMEDrqLDE
i think i'm going to give this a go myself and if i feel i've gotten myself in over my head when attempting it i'll just find someone locally who can solder the cable on to the drivers for me.
i've just ordered my magnum v6 drivers as well as the batch 004 cups from turbulent and since those cups were less expensive than the ones i was looking at from yew woodworks i can now order a cable as well.i'm looking at the 6" cable from venus audio (this one ->http://www.ebay.com/itm/Grado-Headphone-Cable-Upgrade-Canare-Cable-Wrap-Neutrik-Cardas-6ft-10ft-15ft-/121548401848?var=&hash=item1c4cd96cb8
md0GgSgCV6cUvR-hKX2MWCg
i just wish it was 3" instead of 6" and terminated with a 3.5mm plug instead of 1/4" but after all its the same length as if i were to use the Grado SR60i cable (plus looks nicer) and saves me from having to un-solder the Grado cable, and i have
a 3.5mm adapter i can put on it anyway, so unless i find something better suited to my needs for the same price that is the cable i'll use.
totally stoked. now to wait for the parts to start arriving!
