slapshot30
- Jan 6, 2011
Ah, I can;t believe I overlooked that, thankyou! So if I connect the LOD to my E5 will I still hear a considerable difference in sound quality as oppose to just the normal audio output without the amp or even with the amp? (I understand that the E5 itself is not a very good amp) Is the LOD only as good as the amp you pair it with?
Quote:yea it did but what I was trying to get across is that I want to get rid of using the E5 altogether. If I had the second LOD, it has one end going into the ipod and the other end is a male. My headphones obviously have another male at the end of them. Thus creating the need for a female to female. If I were to have the first LOD though that would eliminate the issue.
OH. Ok now I get it.
You wanted to do this:
iPod > LOD > Headphones
You don't want to do that. Ever. Remember, a LOD takes a line level signal from your iPod--which also means you cannot adjust the volume on your iPod.
LODs must always be used with an amp; LODs are useless without an amp.
