semaj8james
- Mar 22, 2013
You sound pretty much like me. EDM, Classical, Dubstep with some gaming in there too. I suggest to you what I had around that price range which are Ultrasone HFI 580's. Audio Technica ATH-M50 are also a good choice. DT770's also are a good idea. I prefer HFI-580's over ATH M50's because of the tight, very present bass, and the very crips highs, which so nice with classical music such as Mozart, Tchaikovsky and Beethoven. I feel like ATH M50's bass are very very close, maybe a bit more, maybe a bit less, as the HFI 580's. I'd say the bass is on par. On both sets of cans the mids are recessed (I fixed that by using an EQ and boosting 250 Hz to 2,5k Hz by 1 dB. As for DT770's, I have no experience with them, but I plan to try them out some time soon.
I'm rather new to the world of audiophile headphones so I'm rather confused all over the place. I don't mind if the headphonesare open or closed. I listen to Classical and Dubstep,DnB,Electro stuff of that sort. One of my concerns is that I plan to stream games and I'm not entirely sure if going with closed would be better considering the lesser amount of leaking and it being picked up by a Blue Spark. I would prefer circumaural headphones. I wouldn't mind picking up a DAC + amp ( It doesn't have to be under $200-250 ) are there any suggested ones to pick up? I know some headphones don't get any additional sound quality with DAC + amps so I suppose it would be better to get a pair of headphones that need/should to be used with a DAC/Amp combo.
