Nope--I'll stay with my earlier recommendations (although the DT 770 has recessed mids). All four cans I recommended are generally considered to very comfortable. Of course what is comfortable for most may or may not be comfortable for you.
hi,
I have the ATHM50s right now, but it's really uncomfortable to me. Although the sound is pretty good, it's also a little too bass heavy for my taste. I listen to a lot of acoustic/jazz/soft rock/instrumental/classical and the occasional hip-hop/rap/hard rock (but no metal). Most of my music is FLAC so I'd love a pair of headphones with great detail, that are fairly neutral (maybe a little emphasis on the mids). I would prefer a set of closed headphones since I will primarily be using them for work and commuting and I don't want to disturb other people around. My budget is $200-250 for the headphones, and I'm not opposed to buying an amp.
You recommended:
-KRK KNS 8400
-Shure SRH 840
-Beyer DT 770
-Ultrasone Pro 750
I went to a local Guitar Center but they didn't have any demo phones. However, I was able to find a local hi-fi store and was able to try (they didn't have the ones you recommended):
-AKG 240
-Another AKG I can't remember
-Beyerdynamic DT 660
-Sennheiser 558
Comfort-wise, I like the DT660 the best, it fit my ears and the pads were soft. I felt that the sound was muted though. I liked the sound out of the 240 the best, but that's a semi-open headset and I don't like that it has barely any isolation and the it wasn't that comfortable. Finally, didn't really like the Sennheiser.
any more recommendations? I can't find any more stores that might have headphones (I'll try Best Buy again)
