You should be fine.
Thank you very much! Are the M50 hard to drive or will my E6 do for on-the-go usage?
You should be fine.
You need a quality studio monitor can that is at least neutral-ish and and has especially good mids. That knocks out the basshead 500 series Ultrasones and "V" shaped EQ (with recessed mids) M50. The V6 is a classic but very long in the tooth. The 780 is fun but too colored for your use.
You need either the KRK KNS-6400, Shure SRH 840 or open box Sony MDR-V900HD. Below that group are the very good for your purposes Sony MDR 7506 & 7510 and AKG K 240 Studio (or MKII).
In my country, Shure SRH 440 fits my price range. What about that? Or another recommendation
Are the Pioneer HDJ-2000s worth the price hike over the HDJ-1500s? Whichever I buy, it's going to be used both amped and unamped (it's replacing both my Sennheiser HD215s which I use at home and my Audio-Technica CKM55s which I use everywhere else). I listen to a little bit of everything and, along with my Yamaha hi-fi amp, my portable devices include a Samsung Galaxy Nexus, a 4G iPod Video and a 4G iPod Touch. The sort of sound that I'm looking for is a lot like my HD215s, except with punchier bass. According to reviews the HDJ-1500 sounds like the set I'm looking for but is it worth the extra $50 to get the HDJ-2000s instead?
After contemplating for a decent while and flip flopping on what I'd like to buy, I've considered either the KNS 8400 or the HD 598 for gaming. As someone who hasn't heard a lot of what's out there, I'm open to any advice from those who've heard either of these or other suggestions. I'm also really curious about the KNS 8400 sound. I've read multiple times that they're neutral, and other times that they're bass light and treble heavy (some even saying the treble will hurt their ears). I've been using the HD 280 pros if that means anything for comparison.
That's a bit of a no brainer. The open HD 598 that is (currently) at twice the street price of the closed 8400 is the better choice for gaming.
The 8400 is the most neutral can that I know of in its price class. It's bass is certainly not greater than neutral and probably a touch below. The Shure SRH 840 is #2 on my hit parade. It has greater than neutral bass due to its mid bass hump and its highs are a bit recessed. Both have great mids.
Yeah, I figured the 598 would be the better overall choice, I just wasn't sure if it'd be worth the price difference. I'd seen some people say the 8400s were good for gaming so I was curious if anyone who'd heard both had anything to say about how well they compare to something higher end.While I'm at it, the Q701s appear to be a strong contender as well, so if anyone here has experience with them I'd be glad to hear about it.
Haven't used them for gaming, but they are great for music and movies. Their large sound stage and great clarity leads me to suspect that they would be great for gaming too. They has decent bass, but are not for bassheads of any stripe. They need to be amped.
Thanks a lot for your input. If you happen to have both fresh in your mind, do you have any input about the sound comparison between the 598 and Q701s?
